5 lbs of boost with 10.8 to 1 compression?
Old Nov 7, 2004 | 06:06 PM
93redz's Avatar
Smile 5 lbs of boost with 10.8 to 1 compression?
i have a built 355 lt1 with a complete forged bottom end....eagle 4340 crank-eagle h beam rods and trw forged pistons.,,i also have afr 54cc cylinder heads which make my compresion 10.8 to 1.. i am going to run 42lb injectors and a tune from pcmforless.do you think the engine will hold up to 5 pounds of non intercooled boost ? the reason i cant run an intercooler is because the engine is in a 69 camaro and i dont have room.i also only run 94 octane gas.
Old Nov 7, 2004 | 06:54 PM
2cub49's Avatar
Re: 5 lbs of boost with 10.8 to 1 compression?
My 100,000+ stocker takes an honest 6 lb non intercooled no problem.
I don't rev it past 5400 rpm though.
Mine's set up for more torque.
Old Nov 7, 2004 | 07:04 PM
93redz's Avatar
do you have water methane injection though?
Old Nov 7, 2004 | 07:56 PM
2cub49's Avatar
Well I have it but I haven't hooked it up.
The powerdyne 6 lb pulley only gave me 4 lb.
I've put the 9 lb pulley in and it reads just over 5 through the mid rpms.
I'm gonna hook up the water/methanol injection in the spring when I reset my shift point from the current 5400 rpm A4 setup up to 5600 or 5800 rpm.
Then I'll probably see 7 lb and have the injection come on at 5 lb.
I have the alkycontrol **** adjustable progressive setup with the stock windshield washer bottle with low level light.
So far I really like the extra torque at mid rpms for daily driving.
93 RedBird
Nov 15, 2015 08:24 AM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
surreybrad
Sep 29, 2015 09:00 PM
1bad427ls1
Sep 23, 2015 01:12 AM
