o2 Sims
Old Nov 4, 2004 | 07:50 PM
Ucantcme57's Avatar
o2 Sims
Need to know info about these how do they work are they any good is there a difference between before cat and after cat sims? Please advise...
Old Nov 4, 2004 | 08:01 PM
blackrat's Avatar
Re: o2 Sims
from what i understand, the precat o2s measure your emissions coming out the engine. the postcat o2s show how efficient your cats are. if your cat isnt working properly, itll throw a engine code. the sims are used when you get rid of your cats with full length headers. they send the proper signal to your pcm that way you dont get that annoying light. there shouldnt be a differance between pre and post because the sim isnt measuring anything, its just sending the proper voltage to keep the pcm happy. you shouldnt need precat sims untill you get radical with your engine. by that point though, you would have to have tuning done and you could just disable the o2s through ls1edit or something.
Old Nov 4, 2004 | 08:24 PM
Capn Pete's Avatar
Re: o2 Sims
AFAIK, you wouldn't want to disable the pre-cat O2 sensors, because they are what measure the air/fuel mixture through the engine, and they determine how much fuel to give the engine. I don't know how else you'd set the air/fuel mixture without O2 sensors on a fuel injected motor?
Old Nov 4, 2004 | 08:25 PM
Ucantcme57's Avatar
Re: o2 Sims
Where do you get them.. Yes I have done away with the heavy cats.. I have four o2 sensors.. Does that mean I have to get 4 sims?
Old Nov 4, 2004 | 08:27 PM
Ucantcme57's Avatar
Re: o2 Sims
So I only need to get post cat sims?
Old Nov 4, 2004 | 08:29 PM
teke184's Avatar
Re: o2 Sims
you only need 2 sims....one for each rear o2 sensor.
removing or putting sims on the front sensors would be like cutting out your eyeballs. the are ESENTIAL to the function of the fuel injection.
not sure where you get your info...but even with radical setups...you still need the front sensors.
Old Nov 4, 2004 | 08:34 PM
Ucantcme57's Avatar
Re: o2 Sims
And they can be obtained for a fair price where?
Old Nov 4, 2004 | 09:01 PM
blackrat's Avatar
Re: o2 Sims
didnt know that pre o2 controls a/f ratio. thought that they just show emission levels. did notice that whenever sims are brought up they strictly the rears. are the factory o2s able to work with a pumped up car or is there a limit to what they will work with since gm probaly didnt have 600 hp cars in mind when outfitting the emissions?
Old Nov 4, 2004 | 10:03 PM
Silvershark's Avatar
Re: o2 Sims
I was also curious about the 02 sims. I purchased some longtube headers and from what I am aware of I will either have to get 02 extensions or 02 sims from my understanding. The third option is to have them removed from the computer. I was wondering if I plan on keeping this car emmissions legal would removing them completely with lt1 edit or custom tuning from pcmforless show up when I went in to get it Imission tested?
I guess I would understand better if I knew exactly what the rear 02's were for.
Old Nov 5, 2004 | 06:25 AM
teke184's Avatar
Re: o2 Sims
the o2 sensors don't deal with "emissions" per-say. they tell the computer whether the car is running lean or rich, which has to do with howmuch fuel is being added.
to a degree that is diffferent from emissions.
Shark, if you installed longtubes then you will need o2 extensions to extend the stock wiring down to the front o2 sensors, AND if you don't have cats or a reprogram you'll need o2 simulators to get rid of the SES
as for buying sims...any of the site vendors will have them, all pretty much the same price. just check around for sales and discounts.
Old Nov 5, 2004 | 12:21 PM
Ucantcme57's Avatar
Re: o2 Sims
Tbyrne Has them... Are they having any group sells...or 10% off sells anytime soon? 89.95 for a pair is their price.. Can that be beat?
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
joffer00
Exhaust System
Dec 22, 2014 03:25 PM
WS6T3RROR
Apr 15, 2003 02:01 PM
lbrowne
Apr 9, 2003 11:56 PM
hotrod18_69
Feb 11, 2003 03:29 PM
