Where to put Jack Stands?
Old Nov 2, 2004 | 07:57 AM
78montecarlo's Avatar
I am going to put the car on stands for winter as I do not want my expensive (to me) Goodyear F1-GS-D3 to flat spot as some people have indicated to happen. I tried searching, and could not find an answer, so where do you put the four jack stands?
Two under the rear axle near suspension mounts and two at that spot behind front suspension and near to the headers where there is a flat piece of the unibody?
Is there any chance of damaging the car by supporting it on these points for so long? ie, is it worse to risk flat spot on tires even if fully inflated, or to risk plastic deformation in frame/axle?
Are any brand jack stands likely to be ok? I have a set of "Rally" brand stands that I got cheap from Walmart or somewhere, but now I do not know if I trust them. The box says they meet ANSI standards, but still. Are any jack stand, as long as the box isnt all in written in some foreign language or something, ok to use?
Old Nov 2, 2004 | 08:48 AM
teke184's Avatar
Re: Where to put Jack Stands?
put the fronts under the control arms...the car is designed to carry it's own weight on it's suspension, the frame is not.
Old Nov 2, 2004 | 10:13 AM
Is there anywhere in particular under the front lower arm? Like under where the shock or spring mount? Or just anywhere that is good and flat? I have not looked at the underside of the control arm in a while and do not remember what it looks like.
What about the rear stands?
Old Nov 2, 2004 | 10:57 AM
teke184's Avatar
yeah i would say anywhere under the arm, closer to the wheel the better.
maybe put a piece of wood under it to evenly distribute weight a little better
Old Nov 2, 2004 | 04:13 PM
Kataklysm's Avatar
For the front put them on the outer most of the control arm. For the rears put them as far out on the axle as you can.
Old Nov 3, 2004 | 12:47 PM
Z28SORR's Avatar
Do not buy the three legged jack stands. Get the four leg ones.
Old Mar 7, 2005 | 02:48 PM
blind527's Avatar
The control arms seem too wide for my jack stands, is this ok? I'll be changing my oil, and all I need to know is where to put the stands.
Victor Lamb
Aug 26, 2017 02:52 PM
Sergio
Jan 27, 2016 04:27 PM
BigWil
Mar 29, 2015 12:24 PM
rick350
Mar 16, 2015 02:59 PM
grgguy
17
Feb 23, 2015 07:57 PM
