High revs, Evil inside!! help
Old Oct 31, 2004 | 10:41 PM
santos's Avatar
Hi guys. I own a 98 Camaro. Since this afternoon it began doing this strange thing. I try to start it, and after third time (always on first) it turned on. But reving like a mad car up to 2400 rpm. Iīve went down to the highway for some miles, cause I thoght that maybe it was the car trying to compensate for low battery. I guess Iīm wrong, the car continue all the way in 2300-2400 rpm. What could it be wrong? anyone with the same trouble?
The only mods Iīve made is the K&N (still not reoiled) a mufler and also I took the cats out. Please any comment would be helpful
santos
Old Nov 1, 2004 | 05:40 AM
rwb's Avatar
rwb
Re: High revs, Evil inside!! help
Do you have O2 sims in to cover for you missing O2 sensors??
Old Nov 1, 2004 | 06:39 AM
teke184's Avatar
rear o2 sensors have ABSOLUTELY NO EFFECT on the running condition of the car. only thing they do is light the SES light as warning of a bad cat.
check all the wires
Old Nov 1, 2004 | 11:04 AM
SSCamaro99_3's Avatar
Did you happen to unplug the IAT sensor, or MAF sensor while you were making the change.
Old Nov 1, 2004 | 12:55 PM
teke184's Avatar
agreed, check to make sure everything is plugged in.
if it is, try unplugging the maf sensor. this will put it into "limp mode" and if it runs alright with it unplugged you could have a faulty maf.
happened to me with an aftermarket zo6 maf....drove fine for months...up and started barely running and hard starting. unplugged the maf and it started and idled fine. switched back to stock and it ran fine since
Old Nov 3, 2004 | 10:08 PM
santos's Avatar
Hi, guys thanks for the help. I went to some friendīs workshop and when I stopped I turned the car off. Then my friend ask me to move it so he can put it in place for check it out. The car didnīt start anymore, the battery was totally dead, not even good for recharging. So I bought a new one. Problem solved!. I donīt know if it was something in relation with the battery going dead but the problem is not present any more.
I didnīt change any O2 sensors or simulators. The car is not giving me any code donīt know if this is actually good. hehe..
thank u all.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
PCLZ28
Dec 24, 2015 05:19 PM
blac94Z
19
May 13, 2015 04:50 PM
carl.froehlich
Mar 13, 2015 12:38 AM
