little pastic/rubber thing on T-tops
Old Oct 28, 2004 | 01:40 PM
1SlowFormula's Avatar
Mine is what looks like it is cracked and one side lifts up, this is the little pastic/rubber thing between the tops at the front. it just looks like it is cosmatic and not really functional, and there is no leaking in the car. I was just wondering what goes into fixing/replacing it! I have sen a few f-bodies at the tack with a similar thing going on, so I assume thid is common.
Old Oct 28, 2004 | 02:33 PM
rlax31's Avatar
Re: little pastic/rubber thing on T-tops
If you're talking about what I think you are there is one at the front and back of the center guide. I had my t-tops broken into and had to replace the center guide, the replacement was missing the rear one. I took my old one off by heating it with a hair dryer, and carefully prying it off. After that It was just glue it on the new top guide. Good luck finding just the plasitc piece w/o the whole guide.
Old Oct 28, 2004 | 04:07 PM
Thanks! I was hoping not to hear that though! Oh yeah that is what I am talking about by the way.
Old Oct 28, 2004 | 09:25 PM
Jeffw's Avatar
i think that is the deflector? it is on the outside edge of the top correct. stock they are rubber. you can get a replacement that is a hard plastic holds up better. in order to change it you have to remove the rail that holds the weather strip for the top of the window so you will also have to buy a new weather strip for that. it is only a small section so don;t freak out it is easy to change. not that expensive. you can leave the strip ripped it does not really affect much.
jeff
Old Oct 29, 2004 | 08:24 AM
Jeff,
Is this something I can just get at the dealership? or is there a better place?
Thanks,
John
Old Oct 29, 2004 | 09:19 AM
Red96Lt1's Avatar
I haven't had the one in the rear for about a year now. Wow, that just sounded really bad.
LastChance719
Cars Wanted
Feb 16, 2015 11:03 AM
siguy
Nov 27, 2014 10:07 AM
The Seer
Nov 20, 2014 06:32 AM
Hal Fisher
Sep 14, 2002 09:36 PM
