88 Firebird 700R4 help speedomeater
Old Oct 27, 2004 | 03:07 PM
crazypurgatory's Avatar
I have a new to me 88 firebird with a 2.8 v6 with a 700R4 transmission.
It has the digital speedomeater plug on the transmission.
What I need to know is this How can I make the speedomeater read 20mph over? I got a ticket the other day and I just can't get the points .
Dam under cover in a crap dodge intrped gray.
I don't like that it's not right fair!!!!
Put light's on it make it look like a cop car than I have no problem.
Don't hide in a bush or under a rock.
Just be seen.
I know I have to get it checked out by a speedomeater place and be
recertified for this to work out for me.
Can any body Please help me with this?
Thanks,
Chris G.
Old Oct 27, 2004 | 04:45 PM
Zepher's Avatar
Re: 88 Firebird 700R4 help speedomeater
You should make it read low, but it really doesn't matter.
You can change the gear in the sender or the rear gears in rear end.
Old Oct 28, 2004 | 08:37 AM
Thanks but I need to know what gear to get for the transmission I know they are different colors for different rear gears.
I need to know witch goes with witch?
Thanks,
Chris G.
Old Oct 28, 2004 | 09:38 AM
WS Sick's Avatar
Well there are several combos you can use, they have different teeth Drive and driven gears in the speedo, determine what rear gears you have, and what driven gear you have, then you can determine what drive gear (one on the tailshaft ) to get. TPIS has a chart in their catalog.
Old Oct 29, 2004 | 07:00 PM
Any body else?
Can I make something and put it inline of the conector to make it read wrong.
Thanks,
Chris G.
Old Oct 30, 2004 | 01:08 PM
aklim's Avatar
Don't waste your time and money. To do it you will probably have to take the tailshaft housing off and change the drive gear too. As a judge said "If a defective speedometer is an excuse, nobody will have a working speedo."
Old Oct 30, 2004 | 07:44 PM
IROC-T's Avatar
You could go to a larger tire size,but most judges won't take that as an excuse either,unless you just perchased the car then MAYBE.
Formula Steve
Sep 19, 2023 08:31 AM
David Dempsey
Mar 12, 2016 12:42 AM
karpetcm
Sep 29, 2015 10:08 AM
Jake Bialke
Sep 24, 2015 11:31 AM
92_RS_305
Sep 8, 2015 07:47 PM
