Blow down tube installation?
Old Oct 27, 2004 | 12:00 AM
MustangEater82's Avatar
Alright I understand why you woudl have a blow down tube.
My question is how do you install it? Do you just unscrew this cap(see pic) and screw the tube on and have it lead out the car somehow?
http://www.porteightyhosting.com/uploads/IMG_0037.JPG
Jsut making sure it is right and I don't just empty the bottle by doing the wrong thing
Old Oct 27, 2004 | 07:29 AM
SDAKOVIC's Avatar
Re: Blow down tube installation?
You will need an adapter first then you can install the tube.Use a thru bulkhead 'AN' fitting to go thru the floor.
Old Oct 27, 2004 | 07:33 AM
sssalah's Avatar
Yes, this is removed and below it is a rupture disc that is discarded. Use a new rupture disc (should come with the tube) and tight the disc down with a good torque wrench to the specified value. This will ensure that the disc gets ruptured at the design rupture pressure.
Old Oct 27, 2004 | 10:01 AM
So if one were to remove it and the bottle was full it woudl likely discharge the bottle?
I am assuming this if you remove teh rupture disc.
Old Oct 27, 2004 | 10:22 AM
LPEdave's Avatar
Yes, if you remove that fitting with the bottle full, all the nitrous will come out. You need to purchase another fitting that's specifically made to hook a blow-down tube to, and unfortunately your bottle will need to be empty when you hook up this fitting. I can't remember a name or part number for it - it'll be a standard NOS part.
Dave
Old Oct 27, 2004 | 11:52 AM
The NOS fitting that screws onto the male threads under the blowoff diffuser cap in the picture is P/N 16170. Includes the adapter fitting, a new rupture disc, and a new diffuser cap on a tether that helps prevent the bottle from spinning wildly, should the disc rupture while the bottle is being transported loose.
You can also attach an -8AN braided hose to the new fitting, if that's how you want to vent the system, rather than using the rigid blowdown tube.
http://cjcfo.fbody.com/members/injun.../DCP03655a.jpg
Old Oct 28, 2004 | 03:16 PM
Alright guys thanks, this all kind of was in the back of my head but I wasn't sure, woudl have been a surprise when I go to open the valve and emptied a full bottle in front of my self
Old Oct 29, 2004 | 08:51 AM
ford's Avatar
My blow down tube wasnt included with my kit when the guy shipped it to me.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Richardan15
May 30, 2015 08:36 AM
jmadoll
Mar 3, 2015 10:16 AM
thenewkid
Nov 18, 2014 12:57 PM
