i need to do a full exhaust
Old Oct 25, 2004 | 02:53 AM
markp03's Avatar
ok i have a compleatly stock 2000 z28....i want to do a full exhaust job from headers on back, and i saw some headers that were between 700-250ish whats good? what do you guys recomand for a full exhaust system that wont compleatly break the bank?
Old Oct 25, 2004 | 04:13 AM
D James's Avatar
Re: i need to do a full exhaust
I'd get cheap headers like pacesetter or maybe the new edelbroke. I'd leave the exhaust alone or put a different muffler on it if you want it a little louder. I think the ideal setup is longtubes with stock exhaust with electric cutout, this way you can have quiet when you are jamming to music and loud when your jamming the throttle down. The electric ones also can be opened up just a little bit, this lets you choose how loud it is, you really can't beat that! Oh yeah the cutouts are cheaper than a whole new catback as well.
Old Oct 25, 2004 | 11:04 AM
markp03's Avatar
ok sounds liek a plan. is the cut out pretty easy to install? and which one would you suggest getting?
Old Oct 25, 2004 | 11:57 AM
BirchMan98z's Avatar
I thought a cutout would be the way to go too, it lost its charm after a couple weeks. Just get a good cat-back. Sound nice, flow well (just as good as a cutout), look nice, and shed a bunch of weight.
Old Oct 25, 2004 | 01:46 PM
DanBUCF's Avatar
Go with the Pacesetter Longtubes...I put 'em in last night. They're really easy to do and fit VERY well. They're also pretty much the cheapest ones out there.
Old Oct 25, 2004 | 02:14 PM
crash4cyl's Avatar
pacesetter LT's and Y-pipe into a decent catback. Keep cats if you don't want the exhaust to raspy. That'll take just about anything you pump through it and still be emissions legal...to an extent.
Chris
Old Oct 25, 2004 | 04:01 PM
dabez1's Avatar
no catback flows as good as a cutout. I agree with D james, nice set of long tubes and a cut out. And maybe a muffler
Old Oct 25, 2004 | 05:02 PM
mebanditws6's Avatar
If you want a cutout, Jegs sells a new type where the bypass piece is attached to a cable that runs into the car where you can open it while driving. Definitely beats an electric cutout (pricewise) and is only around $50. If not, then if you want the most hp gains, go with true duals with X pipe dumped at the axle. Deepest sounding system out there with no rasp.
Jason
Old Oct 25, 2004 | 05:31 PM
Nittanymarine's Avatar
I went with Flowtech coated LT's, (less than $400, fit perfectly, not a single leak) and a True Dual kit from Flowtech as well, with an x-pipe ($109.00) and 2 Dynomax bullets for mufflers turning down at the axle. The sound is truly awesome! I have a cam too, so that makes it all the more better. Thumps nicely at idle, and turns a few heads. Then, when it's WOT, every head turns, and little kids hold their ears.....lol I even had a mom grab her son back from the curb, as I went by at about 3500 rpm. All together I have about $560 in exhaust, from the headers back. Ive owned Borla, and Flowmaster, and this setup owns them all, by far. Other F Body owners have stopped me just to ask which system I have on there. Best sounding, cheapest, and easiest to do IMO. Good luck to ya!
Old Oct 25, 2004 | 10:33 PM
markp03's Avatar
where did you buy your setup marine?
me...I am in the army
Old Oct 26, 2004 | 05:02 AM
AL SS590 M6's Avatar
Moderator
But how much flow do you need? If a cat back will support 550hp and you have 350hp then the "better" flow of a cutout won't make any difference at all. Will it?
Old Oct 26, 2004 | 05:08 AM
Moderator
Originally Posted by mebanditws6
If not, then if you want the most hp gains, go with true duals with X pipe dumped at the axle. Jason
That will also depend upon how much HP you're making. You don't need dual 3" pipes for 350-550hp motors.
Old Oct 26, 2004 | 05:10 AM
Moderator
Where did you get this at? I'm thinking about true duals this winter.
Old Oct 26, 2004 | 05:46 AM
I know of several. Loudmouth, borla, B&B.
Old Oct 26, 2004 | 03:44 PM
PM me for info. Im not sure if they are a sponsor or not.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Brake_L8
Jan 20, 2015 09:44 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
