Was this the proper way to get air out of the radiator?
Old Oct 16, 2004 | 04:51 PM
ishz28's Avatar
Took the cap off and let it run. Since It was already low (can't find where it's going.) I waited till the fans kicked on and added water till it was just below the filler neck. No splatters, but bubbled a lot. Level would go and an down with bubble influxes, sometimes over the filler neck. Waited till the level stopped moving, figured the bubbles where the water boiling. The wierd part, to me anyway, was that when I throttled the car, the level shot down and wouldn't come back up till I added water. Did the throttle/ add water till it only shot down a little and then filled back up on it's own. Is that normal? Thanks for your replies.
Old Oct 16, 2004 | 05:27 PM
texas_z28_guy30's Avatar
Re: Was this the proper way to get air out of the radiator?
see if this helps:
flush, refill, & bleed coolant system
Old Oct 17, 2004 | 03:09 AM
ishz28's Avatar
That's a pretty cool page, thanks.
calaban
May 18, 2020 06:43 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
95chwagon
Jan 13, 2015 09:19 PM
Collector Car
Jan 5, 2015 10:58 AM
