After install questions...noises...?
Old Oct 16, 2004 | 03:56 PM
Mitch666's Avatar
I noticed the moser 12 bolt is loud, but there is a scrapping noise coming from somehwere, but I cant figure out where. I thought it was the breaks, but the rotors arent heating up or being cut into. It doesnt happen all the time, if I hit a bump itll stop for a few seconds, slowing down and breaking. I dont feel any lag in the breaks or anything. Any ideas? If you are sitting in the drivers seat the sound comes from the left in the middle. A friend was sitting in the back and he said it was coming right underneath? Need some help! Thanks!!!
Old Oct 17, 2004 | 05:14 AM
KenP's Avatar
Re: After install questions...noises...?
Did you have to clearance the tunnel near where the torque arm bolts to the rearend? I needed an extra 1/2". Check to see how much room you have there and if there is any marks from scraping.
Old Oct 17, 2004 | 10:06 AM
Mitch666's Avatar
Alright, Ill check that. Any other ideas?
Old Oct 17, 2004 | 11:47 PM
1BAD86Z's Avatar
double check you 4 bolt flanges and make sure they are tight, sounds like your rotor mounts are binding.
you should be able to use a 3/8 inch ratchet with a small 9/16 socket.
also you didn't say what year the car was, are the parking brakes the type with the ring inside of the rotor, i have the same set-up on my 99 silverado and they always make a slight rubbing noise. i've tried to adjust the ring and not use my parking brake but they still make noise.
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
Richardan15
May 30, 2015 08:36 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
