cluth fork
Old Oct 16, 2004 | 11:40 AM
WS6NIGHTMARE's Avatar
cluth fork
ok so the tranny is down and im lookin at the fork and it seems really wobbly, how much play should there be it? should there be some sort of spring mechanism to push the fork back when its not being engaged? This is not a hydraulic(sp?) setup. Just wondering if i need a new fork and/or fulcrom bolt.
Old Oct 16, 2004 | 04:03 PM
firstz's Avatar
Re: cluth fork
there should be just a little play and the preashure plate pushes the fork back i hoped i helped. make sure you put a little grease on on your release bearing. i hoped i helped
Old Oct 17, 2004 | 09:28 PM
)2overt SS's Avatar
Re: cluth fork
There is a little bit of play.. as long as it's not really loose.. you should be fine.
And as firstz said, put a little high temp grease on the throw out bearing (on the inside.. you will notice a little depression, put a little grease there). Also, put the grease on the end of the input shaft, NOT on the splines, but also behind the splines. And for the clutch fork.. put some grease on the fulcrum bolt and a TINY bit on the tips on the actualy fork itself.
Sorry if maybe you already knew that.. but I'm currently about to put back in my tranny.. so all of this is fresh in my mind
Ericksd
Jan 20, 2016 06:07 PM
Ericksd
Sep 16, 2015 07:08 PM
BigWil
Mar 29, 2015 12:24 PM
Briah.hood
Feb 17, 2015 02:10 PM
Cartercarterr10
Advanced Tech
Jan 15, 2015 09:13 PM
