Cold misfire/hot and cold performance?
Old Oct 16, 2004 | 09:45 AM
Jeremy_30th's Avatar
First my car is like day and night with the weather if its say below 60* it runs awsome, if its like above that 70 or 80 it feels like I lost 50hp. Now I know cars make more power in cooler more dense air but this seems extreme. What do you think?
Second in cold weather about 30* +/- when I first start it the SES light flashes and it runs like $hit until its warm (can actually feel it misfiring). Is this possibly related to tuning. My mods aren't that
Posted in LT1 tech also
Old Oct 17, 2004 | 06:18 PM
Alvin@pcmforless.com's Avatar
Re: Cold misfire/hot and cold performance?
Have the codes pulled.
The tune might be a touch too lean or have a bit to much timing which would explain its temper.
Old Oct 22, 2004 | 12:24 PM
I have Autotap and the only code is a Multiple random ctlinder misfire in history. Does not set the SES, but when its cold (below 40ish) it will flash the SES showing misfire unless I idle it up a little for a minute then it wont flash at all..
What kinda timing shud I look for? I have some stock timing tables but as far as my current tune no sure. I have the program I can email you but I can't veiw it to see whats in there.
Old Oct 23, 2004 | 08:28 AM
Today I logged a normal start up w/Autotap. In the morning I'll log it again and compare them. map, iat, timing, maf, coolant temp as well as a couple others. If it don't make much since i'll post it and maybe you can help me.
On another note I'm thinking I have a vaccum leak thats causing it. Dunno, but I'm still exploring that now. Thanks and I'll post some results tomorrow
Old Oct 23, 2004 | 12:07 PM
Try sending a email to Bryan programmer@Pcmforless.com He shoudl be able to look at the files for you and give you a recommendation
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
thenewkid
Apr 12, 2015 07:42 PM
Gtpguy
Jan 26, 2015 04:50 PM
