What is involved in changing the instrument panel backlight color?
Old Oct 16, 2004 | 12:25 AM
91 Camaro RS's Avatar
I would like to change the light on my instrument panel to red so that is matches the paint color and just so that it is different from every other 3rd gen camarp. I need to know what is involved in changing the instrument panel backlight color and what kind of lights it uses to light it up. Any help would be greatly appriciated. Thanks.
Old Oct 16, 2004 | 05:00 PM
ishz28's Avatar
Re: What is involved in changing the instrument panel backlight color?
If the lighting is the same as in the 4th gens. You have to pull the speedo out, take the back cover off. Each area of the speedo is lite by a quarter turn bulb. You can pull the light out of the 1/4 turn mounting bracket and put a new one/color in. Some, you want to keep white, as they go through a green lens. After you have the lights in, hook it back up only, don't mount it. Throw a towel over you head or something else to see if the lights all light up. Learned that the hard way. I did red, but after awhile, it was a pain, didn't really look like the newer cars at all, so I changed mine back. Also, noticed that the color bulbs burn out pretty quick, which is a pain to change again and again.
DirtyDaveW
Dec 1, 2016 05:37 PM
Jubjub
Mar 19, 2015 10:23 AM
silvermansteve
Mar 4, 2015 05:02 PM
siguy
Nov 27, 2014 10:07 AM
