Need help installing emblems
Old Oct 14, 2004 | 05:58 PM
Tattooedlife's Avatar
Just bought 2 69 Camaro script Camaro emblems. The ones that have the studs to bolt through the fender. But the Year One book says you can shave off the studs and install with double sided tape. On my old 85 Camaro I used super glue (I beleive it was the gel kind) to install all the emblems. Has anybody used glue to install there fender emblems? I had no problem with it on my 85 Camaro, but just wanted to see if any body else has done this.
Old Oct 14, 2004 | 07:04 PM
Re: Need help installing emblems
I would use emblem mounting tape.
Old Oct 14, 2004 | 07:07 PM
Were would I get this?
Old Oct 14, 2004 | 08:02 PM
BirchMan98z's Avatar
I just use 3m double sided tape. It's easy.
Old Oct 14, 2004 | 08:09 PM
Do you have to just place peices of 3m at different places on the emblem? Theres no way to put it completely over the whole camaro script emblem.
Old Oct 15, 2004 | 12:47 AM
IROC-T's Avatar
Most auto parts stores sell mounting tape for that,it is black and yes you shold cover as much of the back as possible. Lay out the stripe of the tap, stick it on the back ,and use an exacto knife to trim to fit,then peel and stick on the car where you want it.
Old Oct 15, 2004 | 09:27 PM
Found some 3M emblem and trim adhesive at Advance Auto. Hopefully this will do the job.
Nov 18, 2023 07:21 PM
F'n1996Z28SS
Aug 23, 2023 11:19 PM
