manually shifting 700R4
Old Oct 11, 2004 | 08:36 AM
speedingpenguin's Avatar
Is manually shifting an automatic transmission (Specificly 700R4) bad for it? with a shift kit? is it something i could do all the time or just when racing?
Old Oct 11, 2004 | 12:53 PM
MdFormula350's Avatar
Re: manually shifting 700R4
i usually race at the track in 3rd gear, i manually shift sometimes but found better track times in drive. i manually shift on the street sometimes just to play around and act like i have a manual, but a stockish tranny seems to like drive better rather than manually shifting.
Old Oct 11, 2004 | 01:09 PM
wtf? you mean you put it in 3rd gear to race?
do you mean drive? (unfamiliar with teh cars, dont have one yet...but i always find myself shifting the cadillac manually and i know its gonna be a hard habbit to brake)
meh
Old Oct 11, 2004 | 05:13 PM
WS6NIGHTMARE's Avatar
Shift kit in stock 700R4 = soon to be busted tranny, been there, done it in my old 85 Z28. Come to find out shift kits just really aint that good for those tranny's stock, put a $1700 rebuild on it so it could hold averything, and went to the track, found a very consistent 1/2 second difference between shifting it and not.
Old Oct 11, 2004 | 07:32 PM
well the tranny is rebuilt with less than 3k miles on it...dunno what parts were used though...
Old Oct 11, 2004 | 07:59 PM
12SCNDZ's Avatar
You won't hurt it by shifting it manually. Mine has been shifted manually for the past 4 years while racing...BTW, I've been building automatics for over 14 years...
Frank
Cahall Performance Transmissions
Old Oct 12, 2004 | 11:21 AM
Ucantcme57's Avatar
If your Cable is adjusted correctly you shouldn't ever have to shift it manually..
Old Oct 12, 2004 | 01:37 PM
nah, but for fun, ya know? I sometimes like to have fun shifting it manually, ya know? that way you can control when it shifts and stuff......
Old Oct 12, 2004 | 01:45 PM
madwolf's Avatar
AT WOT, the cable doesn't matter... it's the weights in the governer that determine the shift point.
I've shifted mine manually at the track since I've done a cam swap. Stock shift points aren't any good for the cam and I really don't want to mess with changing the weights.
speedingpenguin, yes, he did mean drive. (as opposed to overdrive)
Old Oct 12, 2004 | 01:56 PM
lol yeah cause the Catera (my current car) has 1-2-3-d-n-r-p or whatever.....so when he said "3rd", to me i thought "eek! 3rd gear its SLOW!", but thats just the catera.....meh, nevermind that then :-P
and yeah, at the track i shift the catera manually cause anything over like4500 RPM's the engine doesnt make much power, so if i shift at 4000 RPM's, it actually shifts more like 5,000 (As opposed to the 6500 that it will go up to in drive)
Old Oct 12, 2004 | 01:59 PM
madwolf's Avatar
What is your Catera's ET/MPH?
Old Oct 12, 2004 | 02:02 PM
Ucantcme57's Avatar
[QUOTE=madwolf]AT WOT, the cable doesn't matter... it's the weights in the governer that determine the shift point.
Where are these weights located?..
Old Oct 12, 2004 | 07:41 PM
best so far is 16.761 @ 83.00MPH
its'a BEAST
Old Oct 12, 2004 | 07:54 PM
12SCNDZ's Avatar
The "weights" are in the governor. The governor is under the round cap that's located on the drivers side of the trans...right in front of the tailhousing. The governor weights and springs control WOT shift points in a 700. The lighter you go on the weights and/or springs the later the shifts will become. They work off cetrifugal force. Fluid pressure pushes the valve in the governor in one direction, until that pressure is overridden by the force of the weights opening.
Frank
Old Oct 13, 2004 | 10:16 AM
Ucantcme57's Avatar
I believe that I had read an article on this.. is there a specfic weight for each hundred rpm's or what? my motor will stop making power around 6100-6200rpm's.. Where can ou buy these weights?
