Ok, who knows a thing or two about 4th gen steering wheels
Old Oct 6, 2004 | 06:05 PM
rlax31's Avatar
Well I'm on my fix-all-the-little-things trip and here's the next thing:
My steering wheel squeaks. If you're sitting in the seat and move the wheel left and right slightly, it squeaks. I know it's coming from the wheel itself. I tried spraying WD40 all up in that piece, but didn't work.
So my question is what inside the wheel would I need to lube, and how do I get to it?
Old Oct 6, 2004 | 10:43 PM
TraceZ's Avatar
Re: Ok, who knows a thing or two about 4th gen steering wheels
The wheel itself press fits on the end of the steering shaft. It has no moving parts. I would suggest removing the airbag to see if you can pinpoint the squeek and eliminate it.
to do this you should first disconnect the negative batery cable
use an allen wrench to remove the 4 screws from the back of the steering wheel into the airbag.
remove the airbag and unplug it. do not touch the connector because static could discharge it.
try and pinpoint the squeak, and maybe get some JB weld in it to silence it?
good luck.
Old Oct 7, 2004 | 07:27 AM
rlax31's Avatar
That sounds like what I needed to know. Now just to find the time...
Airplanedoc
Feb 1, 2015 07:14 PM
CaRParts102
Dec 6, 2014 08:45 AM
ro2207
Dec 4, 2014 06:18 PM
Jul 4, 2005 05:00 PM
SLIMJIM
Jan 7, 2003 11:06 AM
