Front LCA bushing options
Old Sep 27, 2004 | 06:23 AM
RE AND CHERYL's Avatar
I don't feel like going all out and getting expensive tubular front lower control arms. But I would like to replace the stock bushings with something a bit better. I can imagine putting a polly bushing in the rear position would make the control arm impossible to move. Does anyone make anything better like a ball type joint that will press into the stock control arm?
Old Sep 27, 2004 | 08:07 AM
wbna0149's Avatar
Re: Front LCA bushing options
Check with Global west
Old Sep 27, 2004 | 10:58 AM
Z28barnett's Avatar
1LE Front Lower Control Arm Front Bushing (GM p/n 22145392) $15.44
1LE Front Lower Control Arm Rear Bushing (GM p/n 22156434) $35.77
1LE Rear Lower Control Arm Bushings (GM p/n 10164152) (4 required, bushing only) $8.40
* These are solid rubber and not cutaway for soft ride like the stock Z28 bushings. I would expect them to be a pain to install.
* I would just order the arms, save a major hassle. Unless your ride is very low miles.
1LE Front Left Lower Control Arm (GM p/n 52367658) (arm complete with bushings and Ball Joint) $112.72
1LE Front Right Lower Control Arm (GM p/n 52367659) (arm complete with bushings and Ball Joint) $112.72
1LE Front Left Upper Control Arm (GM p/n 22204674) (arm complete with bushings and Ball Joint) $113.28
1LE Front Right Upper Control Arm (GM p/n 22204675) (arm complete with bushings and Ball Joint) $113.28
*I ordered these parts and got the correct parts. They have a blue paint dot on them and no cut away areas on the bushings.
Old Sep 27, 2004 | 12:31 PM
The Energy Suspension polyurethane front upper and lower A-arm bushings are excellent. The ES lower A-arm bushing uses a different design for the "vertical" bushing. It has excellent flexibility with a 3-piece "ball" design, using a hard nylon intermediate ring. It can be done at home, but burning the old bushings out is a bit messy. I have the full ES poly front end.
Old Sep 27, 2004 | 02:22 PM
Z95m6's Avatar
I had originally boxed my stock control arms but i wanted poly bushings. The only problem is the poly bushings cost almost as much as new control arms. So i just bought some aftermarkets.
Old Sep 27, 2004 | 02:23 PM
Don't really want rubber agian. The Global West set-up is like $200 just for the lower control arm bushings. Energy suspension seems a bit more what I'm looking for. Summit Racing sells a complete bushing set for the whole car for $145. Do you know if it includes their upgraded LCA rear bushing?
Old Sep 27, 2004 | 03:13 PM
n2ceptor's Avatar
I have this www.p-s-t.com/ .... Its their kit that retails for 249... I'll cut you a deal...
PM if interested....
Old Sep 28, 2004 | 02:35 PM
OBE1 95Z28's Avatar
I bought the ES poly kit to rebuild the upper and lower control arms. I only used the upper set of bushings as I decided to go with the BMR lower arms (come with bushings) to go with my tubular K member. If you want the ES poly lower bushings I'll sell them for $35 shipped. Shoot me a PM if interested.
HarleyZ28
Oct 5, 2015 06:23 AM
PublicEnemy1
Apr 7, 2015 12:21 PM
dbrockma
Feb 16, 2015 02:56 PM
