size of C-5 rotors???
Old Sep 25, 2004 | 06:46 AM
billsbird's Avatar
.....I've searched but can find nada, What size are the C-5 rotors? Thanks, Bill.....
Old Sep 25, 2004 | 09:10 AM
Z28barnett's Avatar
Re: size of C-5 rotors???
I have the C5 kit.
Rough dimensions are 13" dia, 1.25" thick. You need special brackets to use them. Search under Bob Bishops C5 Brackets and you will find a huge number of posts.
Old Sep 25, 2004 | 05:10 PM
Z95m6's Avatar
i thought the C5's were an inch bigger than the LS1's and i though the LS1's ran 13in. i'm probably wrong in it though.
Old Sep 25, 2004 | 09:42 PM
RE AND CHERYL's Avatar
Yup, your wrong the LS1 rotors are 12".
Old Sep 25, 2004 | 09:58 PM
Z95m6's Avatar
yeah i got to thinking later and i knew i was wrong. I remember my roommate's 94 cobra had 13in rotors and i couldn't believe they were that big and that they were still bigger than even the LS1 setup. Its funny how Ford put a lot of stopping power on a car that didn't have the power to be fast and GM added power but no stopping power to the LT1.
Old Sep 26, 2004 | 08:07 AM
billsbird's Avatar
...Thanks a bunch everyone for the info. I will do a search under Bob Bishop.
13's would {or should I think possitively and say "WILL"???} look fantastic
on my '94 Bird..... Bill....
Old Sep 26, 2004 | 10:54 AM
Z95m6's Avatar
there is another guy that makes the C5 brackets and much cheaper in price. I've never used them though. Although i was planning on gettng them from him when i did C5 brakes but then i got a steal on my LS1 brakes.
Old Sep 26, 2004 | 05:44 PM
Barry 94Formula's Avatar
The C5 rotor is 12.8 inches across.
LT4Firehawk's Avatar
LG Motorsports also makes C5 adaptor brackets, but they only work on the LS1 spindle, so if you have an LT1 you'd have to get the LS1 front spindles as well. They don't list them on the website, so you have to call about them.
Old Apr 10, 2005 | 11:04 PM
ponyackn's Avatar
RE AND CHERYL, I noticed that you're running LS1 brakes with C5 rotors, did you have to do anything special to make that work or is it a straight swap. Is it worth the extra inch or so of rotor?
Old Apr 11, 2005 | 11:55 AM
tryintogofast's Avatar
I actually just completed the C5 brake install on my 95z and I got my brackets from Haulin-***-motorsports.com . There is some modifying that takes place. You cut the old caliper mounts off with a sawsall and then you need to clearence the back bottom of the bracket for a nut. But my GOD I can stop now. No fade whatsoever.
Mikey
HectorM52
Jul 30, 2017 11:46 AM
Boss002
Jan 20, 2016 12:17 PM
asilomar244
Jul 12, 2015 05:53 AM
CARiD
Jul 7, 2015 08:19 AM
