Tranny mount???
Old Sep 18, 2004 | 07:16 PM
BlackMagikLT1's Avatar
Tranny mount???
Hey guys im having a problem with my Z. Today i was flooring the camaro from a dead stop, and i apparantly broke my transmission mount (im an idiot lol), so i bought a new one, and i was wondering exactly how difficult is the installation of it.. I have a 94 auto Z28.
Old Sep 18, 2004 | 07:33 PM
Fuels94TA's Avatar
Re: Tranny mount???
It's not hard at all. Lift the car on jacks, then use a bottle jack and place it under the tranny area. Remove the brace that support the tranny, it also has the mount on it as well. Unbolt the tranny mount from the bottom of the tranny and the brace. Place the new mount back on the tranny first, put the brace back on. Then bolt everything back together. It should take less then an hour to do.
Old Sep 18, 2004 | 10:17 PM
indieaz's Avatar
Re: Tranny mount???
It's about a 30 minute swap if you don't screw around. 75% of your time will be spent jacking the car up and then getting it off the jacks. The other ~7-8 minutes you will be removing the old mount and bolting the new on in place.
Old Sep 18, 2004 | 10:43 PM
Cmr0z28's Avatar
Re: Tranny mount???
Only 11 second factory freaks can break the stock tranny mount.
Old Sep 18, 2004 | 11:12 PM
maddog89's Avatar
Re: Tranny mount???
i broke the mount in my old 94z and it was maybe a high 13 car,never had that one at a track,but its a common problem spend an extra 15 bucks and buy a energy suspension tranny mount you can get them at autozone,i've had no problem in my current z with this mount and its running high 12's,so it is taking some abuse,,,,,,,,,,,,,,,,,,,,good luck
Old Sep 18, 2004 | 11:27 PM
Cmr0z28's Avatar
Re: Tranny mount???
lol we're friends, I'm messing w/him.
Old Sep 19, 2004 | 04:57 AM
Tair's Avatar
Re: Tranny mount???
damn, i gotta do this too
Old Sep 19, 2004 | 07:36 AM
Cmr0z28's Avatar
Re: Tranny mount???
Don't worry....it's very easy. Takes 20 minutes the first time.
Old Sep 20, 2004 | 09:57 AM
ShawnMacAnanny's Avatar
Re: Tranny mount???
It took me 23 minutes to do mine. That was with the time to find the tools, jack up the car, and burn the sh*t out of my hand because i had been 'testing' the car all day, which is how i broke the damn thing.
You can get a new mount from Advanced Auto for like $6.73. It shouldnt take you long at all. Now as for the transmission filter..... never replace it yourself, especially when it's hot and you only jacked the car up a few inches. When that pan falls, YOU NEED TO MOVE!
Old Sep 20, 2004 | 11:52 AM
Tommy'Z 6speed's Avatar
Re: Tranny mount???
I just replaced mine last Thursday.
I got a rubber one from AutoZone for $11.99 (Advance was $18.99 for the exact same part).
I had a Poly one and I felt a bad vibration in the whole floor pan between 54 and 58 MPH. I had tried 2 driveshafts, 3 different sets of wheels/tires, and had replaced the rear U-joint. Still there. I knew it must have been the urethane mount feeding it into the structure.
I don't know if it was due to the material or the slight change in driveshaft angle, but it's much smoother now.
Collinjacobfowl
Jul 30, 2015 09:35 PM
wesley81
Jul 27, 2015 11:31 AM
Jul 10, 2015 02:23 PM
Noer
Parts Wanted
Jul 4, 2015 05:13 PM
