couple quick PVC questions
Old Sep 11, 2004 | 07:07 PM
D James's Avatar
I was thinking of bying that new design PCV that GM has to curb the oil going into my engine. Is GM the only one that sells it, or can I go to the local auto store and get one. If that doesn't help cure the problem, can I just stick a breather filter on the end of it and forget about attaching it back into the engine? I really don't want to do that filter hose catchcan thing I've read about, to much effort on my part, would rather disconnect it. Will i have an problems with it off, like SES or something else? My engine seem,s to burn a little oil and after taking it to the dealer they did some type of test, and said it was normal, and to check th level every 500 miles. This wouldn't be a problem for me, but on hot days I get pinging, and the crappy California gas doesn't help, So I figure ridding of the PVC back into the engine might help
Old Sep 12, 2004 | 12:18 AM
mebanditws6's Avatar
Re: couple quick PVC questions
Changing over to an LS6 PCV will help some but won't cure the oil burning. To get rid of your pinging try running some Seafoam or GM Top Engine cleaner through and switch to a cooler thermostat. The last thing you need on 91 octane is carbon buildup and running at 210+ degrees.
Jason
Old Sep 13, 2004 | 01:31 AM
AL SS590 M6's Avatar
Moderator
Get it at the GM dealer. Cheaper there than at the parts houses here. May help may not. I went with the full LS6 PCV conversion and I'm adding a catch can just for gps.
Old Sep 13, 2004 | 03:24 AM
DARK AGE 53's Avatar
Have you thought about installing an AMW oil catch can, well built and priced right. JMO
Al
Old Sep 14, 2004 | 01:00 AM
D James's Avatar
Al
is there a website or something I can see it-never heard of it.
Old Sep 14, 2004 | 02:13 AM
http://www.accmachtech.com/pcvcatchcans.htm
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
ChrisFrez
Jan 4, 2015 08:43 AM
thenewkid
Nov 29, 2014 04:54 PM
