rear end gear ratio
Old Sep 11, 2004 | 06:41 AM
Stormman's Avatar
rear end gear ratio
Is there a way from my car's vin # to identify the rear my car has?
Old Sep 11, 2004 | 08:05 AM
Capn Pete's Avatar
Re: rear end gear ratio
Check the sticker on the driver's door for the gear code:
GU2 = 2.73's
GU5 = 3.23's
GU6 = 3.42's (<-- but they're for a 6-speed).
Old Sep 11, 2004 | 11:08 AM
Stormman's Avatar
Thanks I'll look at that
Old Sep 11, 2004 | 07:41 PM
Stormman's Avatar
No RPO codes in doors or glove box.
If someone knows how to get this information from the
vin# I'd appreciate it.
Dana from Pro-Built is building me a tranny and he told me to get my rear's ratio form the vin#.
Any help would be great
Thanks again
Old Sep 12, 2004 | 01:00 AM
exolution's Avatar
I bought my camaro without the rpo codes too. I simply called GM and had them tell me over the phone the 40 RPO codes I had.
Old Sep 12, 2004 | 09:42 PM
Capn Pete's Avatar
www.f-body.org/gears
Try that calculator, and try the ratios 2.73 or 3.23, and see which corresponds to what your car does. Should be pretty easy to determine what you've got.
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Jul 4, 2005 05:00 PM
