Best combination to get CR=8.5 - 9?
Old Sep 11, 2004 | 04:48 AM
bogo1's Avatar
I´m in the process of ordering pistons and heads for my blown Gen 1 350" (S-trim, 4-bolt 1pc 350 zz4 block). I've decided to go for the AFR 195s and custom JE pistons. I´m targeting a CR of 8.5-9 but what is the best way (combustion efficiency, reduced risk for detonation etc) to achieve the targeted CR:
#1: Small combustion chamber size (68cc) and large reverse dome pistons or
#2: Large combustion chamber size (74cc) and small reverse dome/flattop pistons?
Old Sep 11, 2004 | 06:31 AM
AdioSS's Avatar
West South Central Moderator
Re: Best combination to get CR=8.5 - 9?
small chamber & large dish
Old Sep 11, 2004 | 07:20 AM
bogo1's Avatar
Thanks adioSS! Since this is more or less "voodoo" stuff for me, I would appreciate if you could you elaborate a little, It´s always interesting to know the basics.
Old Sep 19, 2004 | 08:00 AM
SMOKNZ's Avatar
If you get the AFR's with 78cc combustion chambers, JE extreme duty -31cc dished pistons, zero deck block with a .040 head gasket you'll have right around 7.7:1 compression and will be ready for some serious boost numbers!
Old Sep 24, 2004 | 01:29 PM
PostalZ's Avatar
smokinz, i never got your number or address to send out those stock lifters. they're still here!
Old Sep 24, 2004 | 03:07 PM
SMOKNZ's Avatar
Never herd back from ya, picked up another set off ebay.
brothaslide
Jan 9, 2016 12:11 PM
Camarokid95
Jun 12, 2015 11:25 PM
TitoPR221
May 26, 2015 12:20 AM
