Engine Seems Loose in Bay
Old Sep 9, 2004 | 01:48 PM
Flmac02Z's Avatar
Hey guys,
In my '02 Z28 M6 i've noticed it has lost some power, from what I think it is due to a worn down clutch...42,000 miles on it with the occassional burn out and donut. It's primarily my dad's car and he's been on vacation for the past week so I took it out because he was saying he was hearing some weird noises coming from it. My first thought was piston slap but the tapping goes away after warm-up.
So I was looking under the hood as it was warming up and I noticed it had a rough idle(which it partially my fault) but the engine seemed to be moving, or shaking a little too much than I would expect. It seemed like an engine mount had been cracked or something or maybe something happened with the k-member. I dunno.
Also the "change oil" light comes on at start-up and stays on a couple of minutes even after warm-up when driving. Could this be caused by piston slap?
Sorry about the somewhat long post but basically what I am asking here is this:
What could be going on with the engine that it is vibrating that much in the engine bay and could my piston slap being escalating into a worse condition?
Thanks,
~Kevin
Old Sep 10, 2004 | 02:46 PM
scorp00's Avatar
Re: Engine Seems Loose in Bay
Could be the engine mounts. My first car had them broken. The auto guy floored it and the whole engine jumped up a few inches.
Old Sep 11, 2004 | 02:37 PM
red96taA4's Avatar
yea, it could be the motor mounts. but my 96 ta would shake but it just had a rough idle. the change oil light only comes on for a lil bit, then goes off. so thats normal.
Old Sep 11, 2004 | 04:37 PM
Flmac02Z's Avatar
Thanks guys for the advice...I think when this hurricane is gone(i'm in FL) i'll take her to the dealership and see if it's under warranty or how much it would be for them to fix.
~Kevin
Old Sep 11, 2004 | 06:13 PM
mullettour's Avatar
Actually you probably are hearing piston slap. It normally goes away after warmup.
Old Sep 12, 2004 | 10:46 AM
red96taA4's Avatar
~Kevin
Old Sep 12, 2004 | 12:21 PM
teke184's Avatar
when you start the car, hold the odometer button iin untill the "change oil" light flashes...then let go.
it resets and you don't have to worry about it. mostly a dumby light
Old Sep 14, 2004 | 04:49 PM
Flmac02Z's Avatar
Thank you very much...that has been one of those little things that has been bothering me for like the past...who knows how long...
~Kevin
Klypto
Mar 23, 2016 09:05 AM
alex5366
Mar 8, 2015 11:32 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
formula218
Dec 2, 2014 04:27 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
