low dyno numbers
Old Sep 7, 2004 | 01:44 AM
CtRw's Avatar
Angry low dyno numbers
Had the car dynoed on a chassis dyno this weekend, needless to say I was quite disappointed. Only pulled 277hp and 307tq. The torque seems about right but the hp is ridiculous. My buddies 2000 Z-28 with more miles pulled a 304hp. I did notice an insane amount of richness right around 4800 rpms on both pulls. Any ideas whats goin on with this?
Old Sep 7, 2004 | 09:03 PM
psychocabbage's Avatar
Re: low dyno numbers
what brand of dyno?
Dynojet?
Mustang?
Old Sep 8, 2004 | 12:30 AM
94ZRiCeKiLr's Avatar
im gonna guess dynojet because otherwise his numbers are too high...if your car is running rich you are KILLING its power potential. i picked up 12 hp from my dyno tune just from adjusting the A/F ratio from 11.9:1 up to around 12.9-13:1.
EDIT: also, how high did you wind the car up on the dyno???
Old Sep 8, 2004 | 12:39 AM
Drew778/94Z's Avatar
What size TC, what rear end and gears are you running in your 1983 Z-28 ?
Old Sep 8, 2004 | 02:21 AM
CtRw's Avatar
it was a dynojet, my buddies 2000 Z-28 pulled 285HP on a mustang so obvious i'm a little confused by my numbers on the dynojet. I had him take it up to 6k RPM. I expected my numbers to be lower since he has the m6 and I have the a4 but not that much lower. I'm running stock TC (whatever the 4L60E comes with) and my stock 3.23s until I get my 4.10s.
Old Sep 8, 2004 | 03:26 AM
What year motor and PCM did you get?
Old Sep 8, 2004 | 06:48 AM
Pewter Z's Avatar
Assuming you have a 99 LS1 (from your cardomain page) I'd say your dyno numbers are right on. With a lid and choke-soundmaster exhaust my 2000 Z28 dynoed 291rwhp on a Dynojet. 304rwhp sounds a bit high for a 2000 Z28, not just because it was more than me at the time but seeing numbers other people are posting.
Someone else said it to, dyno-tuning is your friend. Not only can the right person, or yourself, adjust the air to fuel ratio and gain a lot (I gained 17rwhp horsies from a dyno tune) you can also make that 4L60 power shift. My auto now slams your head back when it goes from 1st-2nd
Edit: Sweet looking car!
Old Sep 8, 2004 | 10:53 AM
CtRw's Avatar
Yup, everything is out of a 99. My friend did have a lid (that I gave him since the wrecked car i bought had it on there) and he did a resistor mod to the intake air temp which advances timing 2 degrees, but still my numbers sucked. I'll be going in for a big dyno session this spring, hopefully I can some of this cleared up.
Old Sep 8, 2004 | 11:10 AM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Smile Re: low dyno numbers
Don't get hung up on the numbers. How does the vehicle run?
I have an 01 Z28 with 3.73's and Y3000 2.0STR, with a lid & catback.
293.5RWHP/348RWTQ
Vehicle runs like a scalded ape.
SteveC
Old Sep 8, 2004 | 11:14 AM
CtRw's Avatar
The car runs good and I guess I shouldn't be hung up on the numbers. I did line up with my friend a few nights ago and despite my gears (my 3.23s to his 3.42s) and my huge traction issue I managed to keep with him almost all the way through second. Plus, I get 20MPG in town so I'm happy as hell.
Old Sep 8, 2004 | 01:28 PM
SteveC's Avatar
Thumbs up Re: low dyno numbers
Well then, that's all that matters. I see you have an A4, change the TC to a 3500 2.5 STR and keep the 3.23's. It will make your vehicle into a different animal.
SteveC
Old Sep 8, 2004 | 03:17 PM
NEWBIE T/A's Avatar
I did some searching, and ...
Found some old posts I had when mine was dynoed.
Mebbe some of this will help.
See : http://web.camaross.com/forums/showthread.php?t=156951
I still stand by the "how does it run" as opposed to "how much does it dyno" creedo, although 300+ RWHP sure makes for good bragging rights ...
Britt
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
racecarz28
Mar 30, 2015 09:55 PM
Roadie
Feb 16, 2015 10:34 AM
YellowT/A
Aug 7, 2002 12:30 PM
Joe Brodman
Jul 24, 2002 05:24 AM
