Code 1626: Anti-theft system--Fuel enable circuit. What does this mean?
Old Sep 4, 2004 | 11:25 AM
95LT1Z28's Avatar
I just bought a 1996 Z28, M6 with only 57,000 miles on it the other day. I was starting the car up and it takes a few extra cranks before it fires. Check the normal stuff (fuel pressure, ignition, etc.) and it all checks out fine. So I figure to run my Snap-on scanner and see if it has any codes. It came up with the code: 1626 Anti-theft system--fuel enable circuit. The car will fire up, but it takes a few more cranks than I like. What does that code mean? The previous owner has some sort of non-factory alarm system on it with remote start. Is this code saying that VATS isn't working right? Can I have Bryan at PCMforless take out VATS completely if this is the case and not run into this code anymore? Thanks for any help!
Jeff
Old Sep 5, 2004 | 06:04 PM
wicked_95z's Avatar
Re: Code 1626: Anti-theft system--Fuel enable circuit. What does this mean?
Definitely sounds like a vats problem. I dont think you computer would throw a code on an aftermarket alarm. And yes, Brian can program VATS out completely. Or you could try the resistor and see if that fixes your problem
97Z28Muscle
Feb 6, 2015 10:44 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
STRYKER
Jun 24, 2002 04:27 PM
