12psi, no power???
Old Sep 1, 2004 | 12:52 PM
Gearhead6s's Avatar
12psi, no power???
well i finally got a motor back into my car. its stock with arp head studs and fel-pro head gaskets. i am running a modified turbo tech kit with a 5-7 pound spring in the waste gate and no form of boost control. the boost has spiked as high as 13psi and usually boosts above 8. i run FAST fuel ECU. i ran it for about 2 weeks easy with factory injectors while i waited for the 75# holleys that i have now once we got the holleys as soon as i started it up i fouled the plugs. car ran wful and shook terribly. so after a huge cut in the fuel map and a few other tweaks we got it running with a new set of plugs and it ran smooth as stock. spent a night around town tuning. the A/F stays is at 11.5 under boost and 12.2 out of boost and timing is at 15 degees above 100KPA on 93 octane. i made some passes at the local 1/8th mile and even though i drove terrible and missed most shifts i didn't run the times i wanted. we raced a local stock WS6 LS1 on the freeway on oly pulled like a car on him. my car feels faster than it did stock but no where near what i expected to feel at 10psi. it seems like i fouled another set of plugs at the track because i load fuel when i decelerate and A/F goes into the 9:1 range, car blows black smoke then when i get on it its fine. now my car idls crappy and really rough again and the plugs are wet. i guess i need to find away to cut fuel faster when the TPS reading drops so that i don't load fuel. the best time i got with factory injectors was a 9.2@83mph, with the 75# hollys i could only get a 9.5@81 but that was due to my crappy driving, stock i ran a 8.93@79mph(it was an automatic then too). i guess my question is how fast should it be with 10psi on a stock motor? i am going to get some new plugs in it tonight and try to see if i can get the fuel to cut better then head to the dyno hopefully this week.
anyone have any thoughts or comments on all this? anyone had the same problems?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Keenan
Jan 19, 2023 12:24 PM
DarkKnight
Exhaust System
19
Oct 17, 2016 10:28 AM
NewsBot
May 16, 2015 03:40 PM
XtremeLt1
Sep 13, 2002 08:50 PM
