Front Turn Signal
Old Sep 29, 2002 | 11:54 AM
Z28-CTYHNTR's Avatar
Angry Front Turn Signal
My driver side turn signal is out, its bad enough its already out and I havent even had the car 5 months, but its impossible to get to it to change it! How can I get to the turn signal light? I tried taking off the headlight but I couldnt figure out which bolts where holding it on. Im guessing I would have to get under the car to do it? If anybody knows please tell me
Old Sep 29, 2002 | 12:31 PM
JackZ.Twenty8's Avatar
All you have to do is take off the headlight, feel for the bulb, and twist it out. Then you just replace the bulb and twist it back on. It's simple, really!
Old Sep 29, 2002 | 12:36 PM
Bloodztone's Avatar
Yes you'll have to get under the car and unscrew the flap by the tires (make sure you're not right under it when you bring the flap down, a lot of dust and junk gets in there). There should only be two screws there and the flap will come down. Once there you'll see the housing and wire for the bulb. There should be a gray latch that you pull out and away from the housing to unscrew the bulb. Once you do this the bulb will come out really easy. It's just tough finding that little latch. That should do it and it'll will be a snap to do next time.
Old Sep 29, 2002 | 02:17 PM
Dark Angel's Avatar
I usually pull the headlight, much easier then climbing under the car. There is 1 10mm bolt at the back under the bracket going to the radiator support. Remove that and slide the headlight towards the center of the bumper and you should feel it come loose. Then just pull it out and you have plenty of room to do what you need. Installation is reverse of removal.
Old Sep 29, 2002 | 02:45 PM
nikkev's Avatar
Here's a bad pic of the one bolt you have to take out.It's 10mm.It's the bolt-head that you can see right under the black bracket.Good luck.You'll have to cut and paste the link because it's geocities.
Kevin
http://www.geocities.com/nikkev1/Pics/clearinstall6.jpg
Old Sep 29, 2002 | 02:49 PM
Lightbulb
Thanks a lot for all your help guys, Ill go try it out right now
stangspank
Nov 13, 2015 01:02 PM
Ryabut98
Sep 3, 2002 11:45 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
