does an alternator have a ground ?
Old Aug 30, 2004 | 05:56 PM
ram air camaro's Avatar
i've had a starting problem for a long time and now i'm going to fix it so i need help.
i'm thinking there should be some kind of ground on alternator right or wrong ?
how many wires should be coming out of the alternator harness ?
mine has only one little red wire is there supose to be more
this is on an 94 z28 LT-1
Old Aug 30, 2004 | 06:38 PM
Re: does an alternator have a ground ?
One little red wire and the one larger red wire from the battery is all there is. The alternator is grounded through it's casing and mounting bolts.
Old Aug 30, 2004 | 10:07 PM
yup that's all i see i'll keep looking somewhere else for my low voltage my last option is to replace alternator +battery . i'm going to look at all my grounds and i'll be using your website.
thanks shoebox youve been a big help lately.
Old Sep 4, 2004 | 05:14 AM
smoknta's Avatar
Take your alternator and battery off and take them to a Autozone or Pep boys. They will usually test them for free. This might save you from replacing good parts.
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
autoxr166
Sep 25, 2015 04:21 PM
tommalcolm
Sep 11, 2015 03:39 PM
92_RS_305
Sep 8, 2015 07:47 PM
