How many Relays for Nitrous set up?
Old Aug 30, 2004 | 01:05 PM
Mr_Bond's Avatar
Ok, here what I have. LT1 TNT 100-300 kit(came with relay), TNT purge, NX FPSS , NX TPS (came with relay), NX Fire & Ice heater, MDS digital window switch, MSD digital 6. I have 2 relays. Should I wire the arming system (Nitrous, FPSS, TPS, window, retard) with one relay, or how whould I wire multiple relays (example: 1 for Nitrous kit, 1 for TPS switch, 1 for Heater, 1 for Purge) ?
Old Aug 30, 2004 | 03:04 PM
kevmor99's Avatar
Re: How many Relays for Nitrous set up?
The relays usually handle 30-40 amps. You need relays to take the load off a switch that can't handle it (or if the TPS switch for example can't handle a load of a solenoid ground...it isn't just the positive). I'd have a relay for your nitrous/fuel solenoids being triggered by your fps/tps/rpm/wot switches, for purge (to trigger seperately), and another for your heater.
Old Aug 30, 2004 | 03:28 PM
Mr_Bond's Avatar
So 3 relays total. 1)tnt system 2) Purge system 3) Bottle heater...
Old Aug 30, 2004 | 03:55 PM
kevmor99's Avatar
Yeah...
Old Aug 30, 2004 | 05:31 PM
12SCNDZ's Avatar
I'm using 3 relays in my system, but I'm using a "Maximizer" digital progressive controller. One is for the system/purge...one is for the NX TPS switch...And one is for the "Maximizer".
Frank
Red Hawk 94
Mar 18, 2019 04:03 PM
camaroguy50613
May 27, 2016 09:00 AM
alphaauto
Jan 23, 2015 07:42 AM
bandit383lt4
Dec 21, 2014 09:12 PM
