Procharger questions
Old Aug 29, 2004 | 09:42 PM
Alvin@pcmforless.com's Avatar
I'm looking at a 600B kit. How much power do these realistically support with 1 intercooler?
IF i decided to upgrade the compressor would I have to change to anthor kit or just anthor head unit?
How are the kits?
Old Aug 29, 2004 | 10:41 PM
Lonnie Pavtis's Avatar
Re: Procharger questions
the P600B is good for approx. 750hp depending on the engines base hp rating.
a 2-core 550hp
a 3-core 750hp
a sheetmetal 3-core 1000hp
Old Aug 30, 2004 | 12:33 AM
I'm considering dropping my eaton for a single intercooled kit.. I'm really up in the air but considering i'll go from a 55% eff to a 90 i think it might be worth it.
Old Aug 31, 2004 | 10:30 AM
TenaciousDB's Avatar
The P600B is a bit outdated of a unit. I would consider the P-1SC over the P600B. It's a much newer model and doesn't require you to tap into the oil pan.
The P-1SC and D-1SC share the same bolt pattern and can both be used on the same mounting bracket. I don't think the P600B will be upgradeable without purchasing a whole new mounting bracket. (The D-1, the next line-fed upgrade from the P600B, uses a different bracket if I remember correctly.)
From the look of your sig you're in the neighborhood of being able to use a D-1SC or a D-1 anyway. You might want to consider going with one of those right from the start. The boost curve is a little sharper, with the boost onset being stronger than the P-1SC.
Dave
Old Sep 2, 2004 | 06:46 PM
mzgp5x's Avatar
I ran a p600b with a 12 psi pulley on a 12 rib setup. The shaft key cannot handle the torque. I rolled the key. Then I purchased a D1. Different mount plate and driven shaft (larger). Also tighter fit on a 1997. I removed the 2 core intercooler and run a large spearco. Much less pressure drop. I also made all hardpipe circuit rather than the rubber tube. I purchased the Spearco from E-bay. Very nice for approx $650 US.
D1SC383LT4
Jan 1, 2016 01:56 PM
SmokinZ28lt1
Feb 5, 2015 04:33 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
