6Speed And Our Rear-Ends..
Old Sep 28, 2002 | 08:52 PM
Espo's Avatar
I know 6speeds are much harder for our weak 10bolt because of the sudden transfer of power..
My question is how long will a 10bolt last behind a 6speed car??
I have read about many people blowing them up with Nittos!
I heard low 1.9 - high 1.8s 60foots is as far as you wanna try with a stock 10bolt with 3.23s....
Old Sep 29, 2002 | 12:58 AM
LVZ2881's Avatar
It all depends on a number of variables....
1. what kinda tire..
2. what condition the track surface is in
3. how you drive the car...i.e. sidestep the clutch or slip it off the line.
4. power the car is making
I personally have blown 2 rearends on DR's..
5k clutch dumps on DR's with unimpressive 2.01 60fts.............
a Moser 9" is in the works............
Old Sep 29, 2002 | 06:09 AM
rskrause's Avatar
Moderator
What he said!
Rich Krause
Old Sep 29, 2002 | 07:18 AM
mongse_1's Avatar
Yeah, what Rich said.
Actually, does anyone remember when GMHTP first tested the LT1 F-Body car back in the day? They broke one just by driving it on a track(oval I believe). The car hit a bump and the back tires got off the ground a small amount. The wheels spun free and when they hit the ground again, it was like a neutral drop. Ring teeth go bye bye.
I would think on street tires(GS-C, Comp T/As, etc.) it would be all right. Of course, some are built a little better than others. I've had friends break theirs on their first launch. Mine lasted about 1-1/2 behind a beefed tranny and a 450hp LT1. If nothing else, get the TA Performance cover girdle and use solid crush sleeves should you ever break this rear. It does help.
Old Sep 29, 2002 | 10:37 PM
Grease's Avatar
My rear end finally gave up on the street after making over 200 passes this year with drag radials, alot in the 1.8x 60ft range. I was using Richmond 4.10s but before I buy a 12-bolt I want to try out a new set of GM Motives I just got. They have 37 teeth on the ring gear instead of 41 like the richmonds and I compared them to my stock 3.42s and the teeth are so much bigger. With 37 teeth on the ring gear and 9 on the pinion they are actually 4.11s. It must be a change in design Motive came out with. However if I break this set then its 12-bolt time, besides everything has got to break eventually.
Old Sep 30, 2002 | 05:54 PM
Fastbird93's Avatar
Mine has held up to over two years of abuse under me.
Old Sep 30, 2002 | 10:11 PM
LTOne4Fun's Avatar
No fun playing with a 10 bolt in a six speed car. BTW, i know where you can find a killer deal on Strange rears
Old Oct 1, 2002 | 09:44 AM
GREGG 97Z's Avatar
I made 15 passes earlier this year on Nitto's with the stock 3:42 rear and it held up. I just installed 4:10's and have made 12 passes all but 1 or 2 were in the 1.9 60 ft time and it's holding ok. I actually just purchased an insurance policy on the rear last night though, I picked up a complete 3:42 rear out of an 01 WS6 with only 1200 miles on it. A local speed shop here just installed a 12 bolt for a guy and they just wanted to get rid of the 10 bolt. I'm sure I'm going to need it eventually
Old Oct 3, 2002 | 10:44 PM
Think U Can's Avatar
I have GM Motive 4.10's in my car and I have over 60 passes on them.I cut most of them in the 1.7-1.8 range (a few 1.6's) and it has not blown on me yet.But I am still on the stock clutch and that might help me alittle.
Old Oct 5, 2002 | 10:02 PM
NVMYZ28's Avatar
12.3@115
BONE STOCK rear end......
Stock clutch though - slipping baddly And only a 2.0 60ft time
These rear ends will NOT stand up to "clutch dumps" on slicks/nittos at the track.
Baby it and you might get lucky for awhile.....
Old Oct 6, 2002 | 02:05 AM
twistedwedge's Avatar
I broke mine on BFG radial T/As...
Old Oct 7, 2002 | 12:11 PM
Jerm93z28's Avatar
10 bolt w/$100 torsen and 3.42's here... so far it hasnt let go. im just running an oem replacement clutch, however.
jeremy
Old Oct 15, 2002 | 04:48 AM
LS1 T/A JIM's Avatar
Talking 10 bolt
2000 t/a , 400 rwhp stock 10 bolt gm 4:10 gears, leaving at 5800 rpm dumping clutch, 1.6 and some 1.5 60 ft 12.0, 115 mph 1/4 , 7.5 93mph 1/8 mile gears been in 2 years no problems still quite driving on hwy,
Old Oct 15, 2002 | 03:32 PM
rasilverbird's Avatar
I've seen full bolt on LS1 cars (that went 11.90's) hold on for a full season with ET streets, and I've also seen a lightly modded LS1 pop an axle on street tires. It's all in how you drive, and whether or not you got a good rear from the factory.
Quickss96
Jan 29, 2016 05:56 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
alex5366
Jun 8, 2015 07:52 PM
cristian1311
N2O Tech
Jun 5, 2015 05:08 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
