Difference between the new Spohn TQ Arm and the old one.
Old Aug 25, 2004 | 09:21 PM
xxsaint69x's Avatar
Question Difference between the new Spohn TQ Arm and the old one.
What is the difference between the two? Any advantages?
Here is the pic of mine(older design)
http://bellsouthpwp.net/x/x/xxsaint69x/DSC02192.JPG
and here is the current
http://www.spohn.net/productimages/405_big.jpg
Marcin
Old Aug 26, 2004 | 09:43 AM
IROCZZ3's Avatar
Re: Difference between the new Spohn TQ Arm and the old one.
I believe there were some people breaking them at the slider joint on the older version.
Old Aug 26, 2004 | 11:31 AM
n2ceptor's Avatar
If you look closer they extended the bottom tube for more support, making it a stronger unit...
Old Aug 26, 2004 | 02:32 PM
Ucantcme57's Avatar
I emailed steve about this...
Adj. Torque Arm - Trans. Mounted VS Adjustable Torque Arm - 700R4/T-5 Trans.
I suppose the one with it's own mount is stronger than the one that mounts
to the tranmission? Putting the load on the unibody instead of the
drivetrain?
100% correct!
making this one the better of the two..
http://www.spohn.net/product.cfm?productid=1300
Removes the torque arm pivot point from the rear of the transmission to the supplied crossmember
This one is an EXACT OEM, but stronger...
http://www.spohn.net/product.cfm?productid=1475
Bolts directly in place of factory torque arm using all factory mounting locations.
Old Aug 26, 2004 | 02:34 PM
Ucantcme57's Avatar
Whoops.. Was looking at 3rd gen parts.. Sorry...
DarkKnight
Buyer/Seller Feedback
May 11, 2015 10:03 PM
DarkKnight
May 4, 2015 03:32 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
