Anyone ever ran into a laptop that just wouldn't work?
Old Aug 18, 2004 | 07:27 AM
JasonK94Z's Avatar
Angry Anyone ever ran into a laptop that just wouldn't work?
I got a compaq armada 1750 with windows 98 that was given to me from work. The serial port was working when it was used at work, but it won't work with my cable. I ahve shut down the IR port, the modem, the mouse port, and the keyboard port. Still doesn't work. I can take the cable inside my house and hook it to my new Dell desktop, and the cable passes the aldl test without a hitch, so I know the cable is good. I have never had so much trouble with a computer in my life. This laptop either sucks or I'm overlooking something simple. I'm about to toss it in the garbage.
Old Aug 18, 2004 | 12:40 PM
LWillmann's Avatar
Re: Anyone ever ran into a laptop that just wouldn't work?
have you verified all the port settings in Windows? Compare them to the settings for the port on your desktop.
Old Aug 18, 2004 | 11:26 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
Not sure of the exact model, but I used to have an older (98-99) Compaq laptop that for whatever reason would not work with LS1 edit. (wouldn't read or write)
Old Aug 19, 2004 | 07:41 AM
LWillmann's Avatar
Two guys in my car club are running Compaq Armada laptops, one of them is a 1700 I know. Not sure about the other but it's almost identical to the first.
Old Aug 19, 2004 | 08:19 AM
1fastlt1's Avatar
Have you checked the BIOS? It may be turned off in there.
Old Aug 19, 2004 | 09:45 AM
Compstall's Avatar
Yeah, my HP 1 Gig laptop nearly locks up on me when I try and download Windows Service Pack 1. Works fine up to that point. I can't figure it out.
Old Aug 20, 2004 | 07:14 AM
JasonK94Z's Avatar
The com port is turned on in bios.
Old Aug 24, 2004 | 02:34 AM
Lower's Avatar
I have 2 laptops (One Latitude XPi, and 1 IBM Thinkpad 600E) that won't work for datalogging. I have yet to figure it out too -the serial ports work fine, the cables (both, I bought another thinking maybe the cable was bad) check out OK, and work perfectly from my Home PC using a 50' serial extension.
I even bought a serial PCMCIA card thinking maybe the dedicated port would be the fix. Nada.
I've disabled everything I could that might use a port, there are no IRQ conflicts, and the BIOS have the ports properly setup for both notebooks.
I gave up and am selling 1 of the 2 I had bought. I'll sure be watching this thread to see if you get any answers that work, so post back if you ever figure it out!
Old Aug 25, 2004 | 05:13 PM
jonota's Avatar
I have a 2.4Ghz HP laptop, and also am having trouble connecting. I have AKM cables, Tunercats, and a belkin AND a keyspan rs232 to serial converters and I still can't read.... what gives YO.
Jonota
Old Aug 26, 2004 | 11:19 AM
Don 97 SS's Avatar
I've had a simialr experience with my Gateway PII w/W98. I could never get it to work with Win ALDL for my OBDI truck. I purhcased multiple cables and had computer geeks check everything, but no dice. I gave up. I thought I was the only one with this problem.
DirtyDaveW
Dec 1, 2016 05:37 PM
eazyZ
Mar 1, 2015 07:12 AM
97Z28Muscle
Feb 6, 2015 10:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
Double aught
Parts Wanted
Nov 23, 2014 06:11 PM
