Bottle heater users please enter!
Old Aug 14, 2004 | 08:15 PM
SnakeKilla's Avatar
When you turn the bottle heater on, what kind of psi do you get on your n2o gauge? I had mine on for about 40 minutes in a 68 weather temp. and it was close to 1200psi. I have an autometer electric gauge.
It seems to me kind of high.
Old Aug 14, 2004 | 08:17 PM
n2ceptor's Avatar
Re: Bottle heater users please enter!
YOu might want to search in the N2O Tech section... Prob find your answer there.
Old Aug 16, 2004 | 11:59 AM
Gos2Slo's Avatar
Make sure the little thermostat is working, 1200 is pretty high, you want around 900-950. Get a purge and bleed off the pressure! Otherwise your shot might be fairly lean, not a good idea.
Old Aug 16, 2004 | 03:33 PM
N2O97SS's Avatar
You should be very careful with bottle pressure above 1000 psi. I've used 1000 psi on day's with perfect air, but the plugs are just toooooo white after those passes! As previously posted, shoot for 900-950, and try to warm the bottle over time, so the pressure doesn't drop so quickly once the solenoid opens. I hope this helps.
Doug
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
kandied91z
Aug 4, 2002 02:53 AM
