Biggest rear tires for 99 z
Old Aug 12, 2004 | 01:43 PM
NZ12'S's Avatar
Question? Just got a new 3500 stall and need to know what is the biggest tire size that will fit on stock (rear) 16" rim and not rub? Thanks in advance!
p.s. What kind do you recommend other than the nitto dr. Had those already!
Old Aug 12, 2004 | 02:00 PM
Re: Biggest rear tires for 99 z
Are you looking for street tires, drag radials, DOT or full slicks? Track use only, or street and track?
Are you aware there is a Wheels & Tires forum for questions like this?
Old Aug 12, 2004 | 05:13 PM
NZ12'S's Avatar
Unhappy Re: Biggest rear tires for 99 z
I musta missed that forum...............? Anyway, I'm looking for street tire. thanks
Old Aug 12, 2004 | 08:49 PM
2cub49's Avatar
There's a BFG Radial TA 265-50-16 I'm running that's a full inch taller than stock but it's only S rated for 112 mph though.
Old Aug 13, 2004 | 01:21 AM
psychocabbage's Avatar
the widest that normally fits a stock 16" wheel is 255... BFG..
You can also get Nitto Drag Radials in 245's..
(the difference in a 245 and a 275- which is common for 17" wheels, is 1 inch.. not much difference..)
All too often people just make bad tire decisions.
Make a good choice and traction shouldnt be an issue.
On my Yokohama AVS ES100's 245/50-16 I cant dump the clutch at 4000 at the track.. My clutch wont grab.. Heck, I couldnt even spin them... IF I went through the water I am sure I could.. but warm from the drive to the track and going around the water box, traction was in abundance...
For the price, the Yokohamas offer killer traction and excellent handling characteristics..
F'n1996Z28SS
Aug 23, 2023 11:19 PM
carguy0119
Apr 11, 2016 11:11 PM
Moshbmx1
Jan 20, 2015 03:27 PM
pecaspickles27
Wheels and Tires
Jan 20, 2015 02:31 PM
