tuning for stroker motor?
Old Aug 12, 2004 | 11:35 AM
ss#1230's Avatar
what kind of PCM tuning is required for a stroker LT1. say a 372 or 383.
thanks
Old Aug 12, 2004 | 07:38 PM
joebeemish's Avatar
Re: tuning for stroker motor?
I have modified my motor. Updating for the 383 increase is easy with LT1 edit or tunercat. It is only one parameter in the PCM data tables. The fuel injectors are a little more tricky, but you can also do them with this tuning SW. The tough part is updating for the CAM. I am bringing my car to a professional dyno person for this. I have not found any good info on how to update the PCM tables for CAM changes. I think that is because you need to do trial and error small changes and converge on the correct solution with a dyno without trashing the engine.
Old Aug 12, 2004 | 08:43 PM
97Z-M6's Avatar
all you do is make a little change and then scan it to makes sure its ok. to tune for a cam, its timing and fuel. but you better know what tables to use.
Old Aug 12, 2004 | 09:36 PM
joebeemish's Avatar
You say make a little change and scan to see if it's ok. What do you try to do to timing & fuel? What do you look at to see if it's ok? Which tables? Is there a write up somewhere on this?
D1SC383LT4
Jan 1, 2016 01:56 PM
Jazsun
Dec 29, 2014 12:14 PM
squirrels
Jul 13, 2002 01:58 AM
