What would make my car hum only during right hand turns?
Old Aug 12, 2004 | 08:47 AM
ishz28's Avatar
Question What would make my car hum only during right hand turns?
No matter how fast I'm going the car will hum in a right hand turn, but not in a left hand turn? I have two broken teeth on the ring gear and just figured it was that. Not so sure anymore, the noise is coming from the rear. Why does it only make noise in one direction and not both. The alignment was done recently and the car goes straight, but could it be a front end problem? Thanks for your opinons.
Old Aug 12, 2004 | 09:53 AM
MrDude_1's Avatar
Re: What would make my car hum only during right hand turns?
check if your tire is rubbing on somthing.
the axle can shift side to side a good deal... stock panhard bar/bushings suck. the only reason they dont rub when stock is the large tire clearance..
Old Aug 12, 2004 | 01:59 PM
dabear95's Avatar
I know that when front wheel bearings go bad this happens. It is due to the increase side loading when turning. Perhaps another can confirm if the same happens to the rear bearings?
Old Aug 12, 2004 | 04:42 PM
ishz28's Avatar
Tire rubbing, never thought of that, always thought it was the teeth. I changed the calipers to LS1's, I had to re-route the brake lines, could be those. Thanks for idea. About the hub, I'll shack the tire too see. I have aftermarket LCA's and upper and lower panhard.
Old Aug 12, 2004 | 04:49 PM
ReNxWar's Avatar
Mine does the same thing, except only when going left. I've kind of gotten used to it, its done it since I've had it. Its completely stock.
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
Dec 1, 2014 08:08 AM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
