FreeScan: ? about 02 volts
Old Sep 27, 2002 | 11:35 AM
NONO5.0's Avatar
I was looking at the 'engine data' in FreeScan and noticed that my 02 Volts L change constantly between 0.879 to 0.901 while my 02 Volts R = 0.448 constantly and never changes. Could this mean my right 02 is bad? The SES light doesn't come on and there are no codes stored. Any ideas? This is on a '95 T/A btw
Thanks in advance!
Old Sep 27, 2002 | 03:49 PM
You need to look at the O2 volts in both closed loop and in power enrichment. In either case, if the right sensor voltage is staying fixed at 0.448 V, there's a good chance it is either toasted or disconnected. What you are seeing is the voltage the PCM supplies to the sensor. Odd that it hasn't set a code.
When you start the engine cold, look at both sensors. They should start around 450mV, and then drop over a couple minutes into the 00x mV range. That tells the PCM the sensor is warmed up and ready to go.. and it enters closed loop. Then they should start to fluctuate rapidly between 0xx and 9xx mV's. If you have no activity on the right side, you have a problem.
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
jackpawt883
Sep 10, 2015 08:53 PM
john-e-boy
3rd Gen / L98 Engine Tech
Feb 19, 2003 06:21 AM
CJ Black LS1 Z28 M6
Middle Atlantic
Jun 15, 2002 10:12 PM
