where to start w/timing & A/F with SC??
Old Aug 9, 2004 | 12:40 AM
ss#1230's Avatar
what numbers should i be looking for? im still trying to get more info for tuning my new vortech V-2SQ w/aftercooler, 6psi.
where should i start out with the tuning?
the kit should be here on the 13th, will there be details on how to tune for it?
thanks.....
Old Aug 9, 2004 | 04:50 AM
rskrause's Avatar
Moderator
Re: where to start w/timing & A/F with SC??
12.5:1, 24 degrees max advance under load.
Use the best gas you can find.
Rich
Old Aug 10, 2004 | 12:32 AM
ss#1230's Avatar
24* advance? all ive been reading is talking about retarding the ignition because stock supercharged motors require less timing, and thats why the vortech comes with the crane hi-6 to retard the timing????
im totally new to this whole deal. so if anyone can try to explain a little of this stuff to the tuning impared, id appreciate it.......thanks
Old Aug 10, 2004 | 04:51 AM
SMOKNZ's Avatar
Stock ignition tables at WOT are much more than 24degs. So 24 IS quite a bit retarded. If you are going to be doing this stuff yourself pick up a tuning program such as Tunercat or LT1Edit.
silvermansteve
Mar 4, 2015 05:02 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
GigaMp3z
Feb 20, 2003 02:57 PM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
