Header leak
Old Aug 7, 2004 | 03:41 PM
19formula94's Avatar
Header leak
I believe my passenger side header is leaking, but i cant get my hand down there to tighten the bolts...whats the best angle to get them from and the best tool to use.
Old Aug 7, 2004 | 04:06 PM
teke184's Avatar
Re: Header leak
never done headers on an LT1, but i know when i did my plug/wire change on one it made it VERY easy to access them by jacking the passenger side of the motor up.
i removed the passenger motor mount bolt, but i bet you could get some movement without doing that...could be enough to get your hand in there.
Old Aug 8, 2004 | 05:49 PM
ScrmngChckn95's Avatar
Re: Header leak
I dont know about your lts, but with my shorties some of the bolts on the passender side you can reach with a 11mm deep socket with a u-joint, others I can only reach with an 11mm open ended wrench.
Old Aug 9, 2004 | 03:12 PM
94YellowTAGT's Avatar
Re: Header leak
i use a opened wrench on mine. You just have to twist yourself funny for the number 6 and 8. Good luck.
Old Aug 9, 2004 | 08:27 PM
carlos64030's Avatar
Re: Header leak
Remove your starter and tighten the header bolts from the bottom.
Old Aug 11, 2004 | 11:05 PM
BiGGinZ's Avatar
Re: Header leak
You just have to wedge your hands or tool in there. It might be a knuckle buster but it just needs to be done. I just put my shorties in and I used a sized wrench.
Midnight_Z
Feb 16, 2016 09:36 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
