Should I lock the converter under WOT?
I have a Vigilante 2800 and I believe I can cause the TCC to lock up even at WOT under boost (if not with the factory PCM then certainly with the T-Com).
Can those little clutches hold 600 ft/lbs? Anyone tried it?
Re: Should I lock the converter under WOT?
OK, thats no problem, I locked mine every run we did on the dyno. Locked it widh a switch after i reached third gear before WOT.....
Dont think it should have worked without the switch, stalls to high and hits to hard....
Victor Lamb
Aug 26, 2017 02:52 PM
carguyshu
Jan 22, 2017 11:19 AM
Nellsw88
May 27, 2015 10:27 PM
stockssn2o
May 25, 2015 08:54 AM
