How can I get the car this high? (Teke?)
Old Aug 5, 2004 | 04:02 PM
coogsLS1's Avatar
I am supposed to have my car up around 36" for my header install. Is this correct or will something lower work?
Teke, when you did your install/write up, what was the max lift on your floor jack? I am ready to do this tomorrow just want to make sure everything is going to be high enough.
Old Aug 5, 2004 | 08:28 PM
teke184's Avatar
Re: How can I get the car this high? (Teke?)
i had to use multiple combinations of floor jack, cinder blocks and a piece of 6x6 beam that i had laying around to get the car high enough.
that was after several attempts to slide the headers in. just kindda work on it till you get it high enough.
it helps to have the rear up a little too...gives a bit more room.
Old Aug 5, 2004 | 08:44 PM
coogsLS1's Avatar
i think the max lift on my floor jack is 24"...going to work well enough? Ill have to pick up some cinder blocks tomorrow morning and hopefully get this done in 10 hrs or less.
Old Aug 5, 2004 | 08:50 PM
PatriotTA's Avatar
My Craftsman professional jackstands were fine, but my jack wasn't high enough. I ended stacking wood under the jack and between the jack and the car. It worked out pretty well. I didn't even lift the back of the car at all. I pulled the e-brake and blocked the rear tires, and then just went crazy with the front end. Here's a pic of the headers going in, so you can see what my setup was. You might have to copy the link and paste into a new web browser to see it.
http://www.angelfire.com/punk2/falle...collectors.jpg
Old Aug 5, 2004 | 09:07 PM
madwolf's Avatar
Here's a picture of my car when I did a motor swap. I put the rear on ramps and jackstands on blocks for the front.
Old Aug 5, 2004 | 09:15 PM
PatriotTA's Avatar
That pic never gets old
Old Aug 5, 2004 | 10:42 PM
StreamlineZ28's Avatar
where is that motor swap beingdone, in a container.
very cramped.
Old Aug 5, 2004 | 10:44 PM
Dave89IROC's Avatar
very cramped.
Looks like it was in a U-Haul type storage shed
Old Aug 5, 2004 | 10:45 PM
madwolf's Avatar
Yep, it's a storage unit. Long, but not wide.
No electricity, only one light. Lotsa fun!
I did a stall and cam/lts in the same place.
Old Aug 6, 2004 | 01:09 AM
97WS6SCharged's Avatar
Probably works better with a smaller car. Last one I was in had no air flow at all so it was hotter than hell.
97SSdude
Dec 31, 2014 07:43 PM
ChrisFrez
Dec 15, 2014 03:09 PM
GhostZ28
Dec 7, 2014 11:53 PM
Dec 4, 2014 11:56 AM
USAirman93
Nov 24, 2014 03:37 PM
