New to the sixes and I have a stumble.
Old Aug 3, 2004 | 12:01 AM
revtime's Avatar
We just purchased a 95 firebird 3.4 and finally got it running today (had to have a locksmith fix the ignition lock cylinder) while driving the car if you give it throttle halfway decently it will stumble a bit and then smooth out. Ignition has been done and I am going to throw my scanner on it tomorrow, I think its the TPS but I have not messed with these cars just my 94 Z and was wondering if there is anything that might be wierd about the sixes I might be missing?
Old Aug 3, 2004 | 12:25 AM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
Re: New to the sixes and I have a stumble.
i know its time for a spark plug/wire change when i get a slight hessitation at 3K RPM..
Old Aug 3, 2004 | 12:48 AM
revtime's Avatar
I need to check and be sure but the previous owner just installed new plugs and wires and swapped coil packs with another car to rule out those. It has a new fuel filter as well ( I saw it when checking the car over so I know its new) maybe just maybe the wires are bad or not totally on all the way, I will make sure tomorrow.
Old Aug 3, 2004 | 10:46 AM
joed4640's Avatar
any reason in particular you got rid of your LT1 and got 3.4??
-just curious
oh BTW the TPS usually give the most trouble at idle in park or Nuetral- to diagnoise it w/o a voltometor (sp) simply unplug it and see what happens
Old Aug 3, 2004 | 11:41 AM
camaros_4_lfe's Avatar
sounds like it may be the tps
or more or less a fuel or ignition prob but tps is easiest to check
Old Aug 3, 2004 | 05:28 PM
revtime's Avatar
Still have the LT1. The firebird is for my girlfriend.
Old Aug 3, 2004 | 09:08 PM
revtime's Avatar
Well I put my scanner on it and everything seems to be reading correct except it says quad driver 1 and 4 are bad. not sure what that means.
It also drives fine when cold but when it hits operating temp it starts stumbling and hesitating under load, you give it a good bit of gas and it will stumble a bit and then smooth out.
Maybe ICM? I will try to get that out next and check it.
Old Aug 3, 2004 | 11:16 PM
revtime's Avatar
Ok, went back to the basics and I am sure this is the problem.
2 burnt wires.
I was assuming they were ok since they had been changed but I should have known better.
Putting new wires on tomorrow.
Old Aug 4, 2004 | 01:10 AM
atl2001's Avatar
i win !!
Old Aug 5, 2004 | 01:28 AM
revtime's Avatar
Yep, put new wires in and routed them away from the EGR valve (which is what was doing the damage) and it runs perfect.
Thanks for the help guys.
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
ChrisFrez
Mar 17, 2015 07:31 AM
cmsmith
Mar 16, 2015 02:34 PM
LastChance719
Cars Wanted
Feb 16, 2015 11:03 AM
crYnOid
18
Dec 20, 2002 02:58 AM
