obd1 high stall issues...
Old Jul 31, 2004 | 11:17 PM
1badasZ's Avatar
cant you fix this with tuning or is it better to use that transgo manual kit. i already have the regular transgo kit and dont wanna have to go back in unless i really need to. doesnt someone have a fix for it now with tuning. i dont have the problem yet cause i only have the vigilante 2800 right now but im getting it turned up to a 3200 or so.
Old Aug 1, 2004 | 11:21 AM
flyinZ's Avatar
Re: obd1 high stall issues...
Did you have somebody do your tuning? You could always get ahold of "Madwolf" and ask him...Im sure he could set u up..
Old Aug 1, 2004 | 08:44 PM
1badasZ's Avatar
i wont have the car running until this week so no i havent done any tuning. i pm'd him and emailed him too i think but i havent heard anything from him yet
Old Aug 1, 2004 | 08:56 PM
formula383's Avatar
I have the problem right now. I have Brian at PCMFORLESS doing my tuning. He says he still has a few things that he can try to hopefully get rid of my no shifting problem.
I would also like to know what else can be done to cure this aside from the tuning.
Old Aug 1, 2004 | 11:33 PM
flyinZ's Avatar
Nothing, besides tuning will cure it...Unless, you dont have a "stall" in your car..Sometimes, it will happen with a 3k stall, sometimes it wont...It just depends on the car..Either of the two tuners, will get you guys worked out no prob..
Old Sep 20, 2004 | 07:02 PM
90 Z28SS's Avatar
I wouldnt say that. Ive been trying to get mine with a 3200 stall to shift for the last month or so without crashing into the rev-limiter . I know what Im doing with the trans tables and shift settings and Im about to give up on mine . I got 1-2 to shift consistently at 6025-6150 ( it wont hit an exact # ) pretty consistently by telling the pcm to shift at 20 mph which corrolates to 2700 rpm with the rear gears I have , then in the mph tables set 100% tps 2 mph higher at 22 . 2-3 I have to set at 69 mph ( 5000 rpm) to get to shift at 6100 . If I try to raise the shift points any higher than that ( I need to shift at 6900-7100 ) , it's just like theres nothing set at all and both 1-2 and 2-3 run right staight up to the rev-limiter I have set 7400 .
The cable adjustment fix has to be made up . I have a b&m cable on mine that I know is not out of adjustment at all .
As long as this prob has been discussed Ive never heard anyone with a answer yet , other than switching to an OBD2 computer. Ive got countless hours of computer programming trying to chase this and Im about to give up .
Old Sep 20, 2004 | 07:09 PM
smoknta's Avatar
I have heard the stock PCM wont handle anything over 7000 RPM. Is this true?
Old Sep 20, 2004 | 07:19 PM
90 Z28SS's Avatar
It varies from pcm to pcm . I had one that woudnt go over 6800 . The higher rpm pcm's are less common but there are some that will keep on going . 7600 is the highest Ive heard and like I said mine did not shut down bouncing off the rev-limiter at 7400 ....yes , my sig is outdated
Old Sep 21, 2004 | 12:10 AM
1badasZ's Avatar
well i finally got mine together and now it wont shift. i didnt have this problem before the heads and cam. now the tranny wont shift. what gives?
Old Sep 21, 2004 | 12:40 AM
Gord's Green Z28's Avatar
The heads/cam bumped up your torque converter stall. You're probably stalling at 3200 right now even though you have a 2800.
Old Sep 21, 2004 | 05:26 AM
90 Z28SS's Avatar
Apparently from what Ive been able to find by searching the net , Bryan @ pcmforless and Ed Wright have solved this problem . A table was found in the pcm having something to do with scaling stall speed vs. speed sensor output . GM's set value was 2400 and nething to much over will throw the trans into a limp home mode , causing the gears to jump around like going from 1-3 , or just run right up to the rev-limit because the PCM got no signal to shift .
Also discovered for those that dont mind to shift on their own , transgo make a Manual electric valvebody incorporating a toggle switch ....letting shift automatically or flipping a switch and making it a FULL manual . The info I found was about 6-7 mos. old . Damn , where the hell was I , lol
Old Sep 23, 2004 | 09:11 AM
1badasZ's Avatar
mine just wont shift at wot. everything else is fine but at wot it goes all the way to the rev limiter everytime
RUENUF
Mar 13, 2016 03:39 PM
lildemars09
May 28, 2015 07:54 PM
beltrunner
May 17, 2015 10:18 PM
greenzee28
Mar 26, 2015 09:13 AM
