my trans is bucking??
Old Sep 25, 2002 | 07:48 PM
EAZE E 96Z's Avatar
Question my trans is bucking??
today while i was riding on the highway i decided to let's say floor the pedal because i had thought that early in the day that i felt the transmission buck somewhat when i made a turn. so i head out on the highway and i get to about 70 mph and decide to hit the pedal to the floor to see how the transmission react's, i then floor the car and the car bucked about 3 times after flooring it, i right away step off the pedal and say to myself there's a problem!
what could the problem be guys?
eric
Old Sep 25, 2002 | 08:46 PM
psychocabbage's Avatar
if it made a thud under your car and sounded like it was banging, then your tranny mount needs to be replaced. I would suggest the Energy Suspension unit.
Old Sep 25, 2002 | 09:05 PM
EAZE E 96Z's Avatar
yep..you got it. it did what you just said..thanks for the info!
eric
Old Sep 26, 2002 | 03:45 PM
Big Red Jim's Avatar
It most likely is the transmission mount (these cars are notorious for ripping those babies. A less likely scenario would be a failing fuel pump, but I doubt that's your problem.
Old Sep 26, 2002 | 03:55 PM
EAZE E 96Z's Avatar
thanks jim, i was going to take the car for a test ride today but it's raining pretty hard right now. i'm going to take it to the dealer next week to have the problem checked out.
thanks again!
eric
Old Sep 26, 2002 | 04:06 PM
tranny mount is an easy fix. from my experience, if it fails.. it will do so again.. and probably sooner.
Thats why I went for the end all ES tranny mount.. its fail safe so if the unthinkable were to happen and it did fail, it would still work! hehe
Old Sep 26, 2002 | 08:45 PM
Pewter99_Trans's Avatar
I tihnk I might be having the problem psychocabbage was describing. Like every now and then if I pull out of a stop sign or something nice and slow ill hear kind of a thud almost come from where the transmission is and then it feels like it knocks into gear/ Is this the saem thing your talking about? Could yall describe what I should do if I have the same problem.
Old Sep 26, 2002 | 09:56 PM
Also if you all think that I have the same problem as eric did how much would it cost to get a tranny mount and have it installed? Can anyone tell me where to find the energy suspension tranny mount?
Old Sep 26, 2002 | 10:02 PM
EAZE E 96Z's Avatar
i just checked on www.slponline.com
the part is only 19.95 and the install should be about the same.
eric
Old Sep 26, 2002 | 10:14 PM
Thanks for finding that man. Have you had yours put on yet eric? Did what I said my car was doing sound exactly like yours when it was shifting out of second it made a thump?
Old Sep 26, 2002 | 10:52 PM
Honestly, if you can change your own tires, you shouldn't pay someone to install the tranny mount.
Jack the car up, unbolt the mount, jack the trans up, and slide the new mount in. Lower trans, bolt mount to crossmember, let car down. Done.
Old Sep 27, 2002 | 08:45 AM
EAZE E 96Z's Avatar
my car only made the sound when i floored the car going 70 mph. the trans bucked about 3 times when i had the gas to the floor.
i have not bought the part yet and i'm looking to install the part myself.
eric
Old Sep 27, 2002 | 10:26 PM
Do yall think that I need to replace my tranny mount.....is what I am experiancing needing my tranny mount to be replaced?
Fastbird93
Apr 9, 2016 07:01 PM
69z-28
Jan 29, 2016 10:46 PM
Fastbird93
May 22, 2015 08:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
