High pitched screech/squeel only when turning left??
Old Jul 19, 2004 | 08:00 AM
rob2299usa's Avatar
Exclamation High pitched screech/squeel only when turning left??
Just as the title says I get a very loud, very embarassing screech whenever I turn left. It sounds like it's coming from the rear left side wheel. I even hear it sometimes when I'm on the freeway going into a left hand curve. The speed of the screeching increases as vehicle speed increases. I originally thought that it could be brake related but after looking at the brakes I am starting to wonder if it is something internally wrong with my rear end. I had all the bearings replaced when I had my gears installed. What gives?? It's driving me nuts... Thanks in advance.
Old Jul 19, 2004 | 05:39 PM
flyinZ's Avatar
Re: High pitched screech/squeel only when turning left??
Im in the same boat as you, and i can't find it either...The next time you hear that noise, hit your brakes to see if the noise quits or not..That should eliminate the brakes, id think..
Old Jul 20, 2004 | 12:34 AM
weavz28's Avatar
I have had the same problem as both of you two. I had bigger rims put on and have always thought it was just the tires rubbing, but never really sure. It bothers me everytime I hear it. Hope someone knows whats going on here.
Old Jul 20, 2004 | 07:36 AM
rob2299usa's Avatar
Exclamation Re: High pitched screech/squeel only when turning left??
I normally try to do all of the work on my car but I am just so frustrated with this right now that I almost feel like taking it somewhere!!
Old Jul 20, 2004 | 09:08 AM
n2ceptor's Avatar
My front wheel hub use to make a humming noise when turn at highway speeds... That might be it.... If you are sure its from the rear, might be an axle bearing going out...
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CaRParts102
Dec 6, 2014 08:45 AM
formula79
26
Aug 5, 2002 12:21 PM
