Pro 5.0 Guys w/T56: INSIDE PLEASE
Old Jul 18, 2004 | 10:12 AM
Hyperspeed97z28's Avatar
On the shifter stick, the 2 bolts that hold the stick on, Mine keep viberating loose and the stick starts wobbling...
Have anyone of you had this same problem?
What can I do to fix it?
Can I simply locktite these 2 bolts with the shifter still installed ??
Old Jul 18, 2004 | 10:44 AM
Bud M's Avatar
You don't need to use Loctite but some guys do. I just crank 'em down good and tight.
Old Jul 18, 2004 | 11:29 AM
Josh'95Z28conv's Avatar
I used locktite. They havent loosened up a bit
Old Jul 18, 2004 | 11:59 AM
Black6SpdTA's Avatar
Same thing happened to me a few months ago. Used some threadlock and no problems since.
Old Jul 18, 2004 | 12:50 PM
Cool,
Thanks for the fast reply's guys ....
Is it OK to tighten these 2 bolts down with the shifter installed?
I'm gonna have to get some locktite later... What do you suggest?
This is the 4th time these bolts loosen'd on me.... I dont want to do it no more, so this locktite should be strong, lol...
Ahh the love of these cars...
Old Jul 18, 2004 | 06:25 PM
carlos64030's Avatar
Re: Pro 5.0 Guys w/T56: INSIDE PLEASE
I just bolted my bolts down really tight and I haven't had any problems. If you're going to use Lock-Tite...get it in medium strength (blue).
Old Jul 18, 2004 | 09:21 PM
1984camaroz28's Avatar
yea hype i have the same problem on my pro 5.0 they keep coming loose ever month or 2
Old Jul 18, 2004 | 09:49 PM
I'm gonna try the lock-tite tommorow and I'm sure that'll fix the problem.
Thank you guys for the advice !!!
Old Jul 19, 2004 | 11:21 AM
Fast Caddie's Avatar
Mine did that a few times during the first couple of months i had it. Then one day i got pissed off and torqued the **** out of the bolts and it has held fine for the last 9 months or so. No locktite, just torque. Come on boy, put some elbow grease into it
Old Jul 19, 2004 | 11:33 AM
97FormulaWS-6's Avatar
Do you have the lock washers on the bolts? If not, add some lockwashers.
I don't loctite mine, I just use the lockwashers, and mine never come loose.
cmyname1
Feb 16, 2015 08:33 PM
x7x7
Aug 15, 2002 06:49 PM
jim88iroc305
Aug 13, 2002 09:24 PM
Red97LT1
Aug 7, 2002 05:45 PM
Krab
Aug 5, 2002 12:08 AM
