rear end oil change how much do i need to put?
Old Jul 13, 2004 | 03:11 PM
ram air camaro's Avatar
does some one know how much gear oil and additive do i need to put do a comlete rear end oil change?
Old Jul 13, 2004 | 08:39 PM
Eruption's Avatar
1 1/2 to 1 3/4 of gear lube and 1 bottle(not sure what the oz is) of GM additive. Hope this helps
Old Jul 13, 2004 | 09:51 PM
unvc92camarors's Avatar
check brent's site
lt1 tech moderator
Old Jul 14, 2004 | 03:12 AM
stik6shift93's Avatar
It should take about 1 1/2 quarts, if you don't have a zexel posi you'll also have to add the limited slip additive. I believe gm calls for 4 ounces of additive. With my ta girdle cover i can almost fit 2 quarts in, no additive though.
Old Jul 14, 2004 | 10:32 PM
revtime's Avatar
I have a TA girdle as well 1 3/4 quarts of synthetic and GM additive.
Old Jul 14, 2004 | 11:22 PM
thanks on the info it has a stock posi with 4:10 gears and it's going in my a-4 . thanks again
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
ModdedNerd
Dec 25, 2014 05:51 PM
FredM
Dec 18, 2014 01:40 PM
