pros/cons 4.10 gears
Old Jul 10, 2004 | 02:31 AM
coogsLS1's Avatar
being that I want 4.11 gears but they obviously wont fit in the stock 7.5 rear, I am probably going with 4.10s. Any downfalls besides sacrificing some top end? Sounds like a pretty good mod for the money!
Old Jul 10, 2004 | 03:20 AM
Capn Pete's Avatar
Ask around for which brand, but 4.11's are available for the factory 10-bolt AFAIK. They're 37 & 9 teeth, instead of 41 & 10 like 4.10's are, so yeah, they should be stronger.
Try searching for "4.11" or "4.11's" in the Drivetrain forum.
Old Jul 10, 2004 | 03:28 AM
coogsLS1's Avatar
I did for a long long time, seems like you are on almost every gear thread....smart man.
I like the fact that the gm gears are quiet and dont want to go thru the same problem you had with whinny gears.
Where could some gm 4.11s be found?
Old Jul 10, 2004 | 10:35 PM
SlidewaysZ's Avatar
I think you will be happy with 4.10's. I have them in my 94 Z and love them. With having the 6spd I have the best of both worlds. The pull 1st thru 3rd is awesome and you can still cruise out the highway in 6th. Running 70mph in 6th Iam somewhere around 1700 to 1800 rpm. I am sure someone else on the board has them ask around. Hope this helps
Old Jul 10, 2004 | 11:22 PM
JoeliusZ28's Avatar
IMO the only downfall to 4.10s/4.11s is having to shift like in a semi truck when casually accelerating from 0-55 or so.
Old Jul 10, 2004 | 11:35 PM
Dave '97 Z28 M6's Avatar
Here's a handy link for calculating speeds with different gear ratios:
http://f-body.org/gears/
Old Jul 11, 2004 | 01:21 AM
Eliminator's Avatar
I have 4.10s and like them, so far cant say anything bad.
Old Jul 12, 2004 | 12:24 PM
Jay-Roll's Avatar
Pro: Pretty much just about everything.
Con: Traction
You will love em, I recommend the potentially stronger 4.11's as well.
Old Jul 12, 2004 | 01:54 PM
importeater's Avatar
Only if you use every gear.. For around town driving I only ever use 2,4,6.. No real need for the other gears, not even 1st. Saves some gas too that way.
Old Jul 12, 2004 | 03:02 PM
LT4Firehawk's Avatar
The only con I can think of is noise. I had 4.10s in my 95 for over 3 years, and they whined a bit (although not much more than the stock gears in my Firehawk), and when cruising on the highway at 80 there was a lot more rear end noise (not just whine). Try cruising at 90-95 and see how everything sounds as that is about the same as 80 will be with 4.10/4.11s. There is often a cyclical resonance/harmonic/something at that speed that can be very irritating.
Otherwise, I love 4.10s and even with the above issue I'm still thinking about doing them on my Hawk.
Drtryder
Apr 22, 2015 04:17 PM
camy 1993
Feb 1, 2015 07:16 PM
Noer
Parts Wanted
Jan 19, 2015 10:19 AM
GRN96WS6
Sep 8, 2002 10:45 PM
funina91ss
Aug 6, 2002 11:20 PM
