Flashers dont work
Old Jul 6, 2004 | 12:45 AM
NewbieWar's Avatar
Flashers dont work
well the **** doesnt do anything but click when i pull it down or push it up...
the last few months its been inconsistantly having a "hyper blinker" and recently it just stoped working all together...
what is the suspected problem how much would the problem peice cost and how long might it take a first timer?
Old Jul 6, 2004 | 09:06 AM
NewbieWar's Avatar
the lights on the dash dont blink and the lights on the corner of the car dont either
Old Jul 6, 2004 | 09:22 AM
Fuels94TA's Avatar
It can be something simple as a bad flasher relay located under the dash. How about your hazard light's do they work?
Old Jul 6, 2004 | 09:40 AM
NewbieWar's Avatar
yes the hazards work just fine
Old Jul 6, 2004 | 10:52 AM
wiked95ta's Avatar
Look for the flasher relay under the dash. if they relay is touching some sort of metal of the car it'll be grounded out. that relay can't touch any other metal. If the relay was toast then you could turn the blinker on and the arrow would go on solid in the dash.
Old Jul 6, 2004 | 02:26 PM
Fuels94TA's Avatar
What I did was swap relay's from the hazards to the flasher out. To see if it's a bad flasher relay. If so you can fine another relay for like $10 at any part store.
Vinny
Old Jul 6, 2004 | 08:30 PM
NewbieWar's Avatar
ok so i dont have a solid light on my car... does that mean that the relay is not toast?
no blinker at all turns on on the dash or anything
Old Jul 7, 2004 | 11:00 PM
NewbieWar's Avatar
so how do i test thro the hazard relay?
Old Jul 7, 2004 | 11:18 PM
Fuels94TA's Avatar
I thought your hazards were working from your other post?
Old Jul 8, 2004 | 10:02 AM
NewbieWar's Avatar
they do but u guys were telling me to test something thro some kidna relay
Old Jul 8, 2004 | 08:11 PM
Fuels94TA's Avatar
What I was saying was switch the relay from the hazard over to the flasher. Both relays are alike, by switching them if the flasher start to work then you know the relay was bad on the flasher. If you can find shoebox web page it will have pics of the relay location to aid you.
Old Jul 8, 2004 | 08:59 PM
NewbieWar's Avatar
well shoebox's picture is pretty general, is there a better pic specifically for the flasher check?
Red Hawk 94
Mar 18, 2019 04:03 PM
blac94Z
Feb 18, 2015 11:36 AM
squarehead
Jan 15, 2015 07:02 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
